LM2675 12V to 3.3V Conversion Circuit Check with PJ-006A-SMT-TR Jack Compatibility
354 6
  • Request to verify LM2675 12V-to-3.3V circuit and jack compatibility
    #1 21668907
    mano Chitra
  • Check jack supply pin against PCB ground first
    #2 21668908
    Mark Harrington
  • DC jack switch disconnects battery when plug inserted
    #3 21668909
    Frank Bushnell
  • #4 21668910
    Mark Harrington
  • Check jack pins and continuity with a DVM
    #5 21668911
    Mark Harrington
  • Clarifying PJ006A jack wiring to LM2675 VIN
    #6 21668912
    mano Chitra
  • #7 21668913
    mano Chitra
The discussion centers on verifying the correct circuit connection for converting 12V to 3.3V using the LM2675 voltage regulator with a 12V wall adapter (EMSA120150-P5P-SZ) and a PJ-006A-SMT-TR power jack. Key points include the proper wiring of the PJ-006A jack pins: Pin 1 (center pin) should connect to the LM2675 VIN, Pin 2 (outer sleeve) to ground, and Pin 3 (battery disconnect contact) can remain unconnected if no battery is present. It is emphasized that Pins 2 and 3 should be grounded or handled correctly to ensure proper switching and avoid circuit faults. The current rating of 1.5mA from the adapter is insufficient for the LM2675, which has a quiescent current around 20mA, indicating the power supply choice may be inadequate. Troubleshooting suggestions include using a digital voltmeter (DVM) to verify supply voltages and continuity checks on the PCB tracks around the jack pins to detect broken connections or faulty plugs. The discussion clarifies the function of the third contact in the PJ-006A jack as a switch to disconnect internal battery power when external power is connected.
