How to Control 3-Wire 24V Pool Valve Actuator With Timers for Pipe A/B Switching?
417 6
  • Using relays to switch 24 VAC between actuator wires
    #1 21670020
    Nash Rack
  • #2 21670021
    Chuck Sydlo
  • #3 21670022
    Steve Lawson
  • Need to determine whether actuator is latching or motor-driven
    #4 21670023
    Mark Nelson
  • SPDT relay wiring for 24VAC actuator control
    #5 21670024
    stephen Van Buskirk
  • Timer overlap to avoid unsafe valve states
    #6 21670025
    Steve Lawson
  • #7 21670026
    Nash Rack
The discussion addresses controlling a 3-wire 24V pool valve actuator to switch water flow between pipe A and pipe B at scheduled times using timers. The actuator requires 24V applied between wires x and y to move in one direction, and between y and z to move in the opposite direction, with y as the common wire. Key considerations include whether the actuator needs continuous voltage to maintain position or only a pulse to switch states. Solutions involve using one or two timers combined with relays (SPDT or DPDT) to switch the 24VAC supply between the x and z wires while keeping y common. A single 24VAC transformer can supply the actuator, with the timer controlling a relay coil to select the output wiring. For actuators needing only momentary voltage to switch, timers can be set to provide short pulses at the desired times. For continuous voltage requirements, timers must overlap outputs carefully to avoid conflicting signals. Sprinkler timers providing 24VAC were suggested as a cost-effective alternative to expensive pool control systems. Overall, the approach combines a 24VAC transformer, timers (such as GE 15154), and relays to achieve timed directional control of the valve actuator.
