Best MOSFETs for Driving 12V Solenoid With 3.3V Logic From Spark Core Board
1194 11
How can I drive a solenoid from 3.3V Spark Core logic?
Use a logic-level N-channel MOSFET as a low-side switch: put the solenoid on the positive supply side, connect the MOSFET so it switches the return path to ground, and drive the gate from the Spark Core GPIO [#21673752][#21673762] Add a flyback diode across the solenoid to clamp the reverse-voltage spike when the coil is switched off, because that inductive kick can damage the MOSFET [#21673752][#21673757] Tie the solenoid supply ground to the Spark Core ground so the gate drive has a common reference [#21673753] A BS170 was suggested as a simple choice, but it is only about 500 mA continuous and about 1200 mA pulse, so use a higher-current MOSFET if your solenoid needs more than roughly 250 mA to stay on [#21673752][#21673753] If the circuit behaves oddly, double-check the MOSFET pinout because some parts have different lead arrangements [#21673760]
  • #1 21673751
    Luke Weston
  • Logic-level N-channel MOSFET with flyback diode recommended
    #2 21673752
    Screaming Circuits
  • BS170 current limit and separate solenoid supply wiring
    #3 21673753
    Screaming Circuits
  • #4 21673754
    richard gabric
  • #5 21673755
    Luke Weston
  • #6 21673756
    Luke Weston
  • Flyback diode needed for inductive load switching
    #7 21673757
    Screaming Circuits
  • #8 21673758
    richard gabric
  • #9 21673759
    Luke Weston
  • #10 21673760
    Screaming Circuits
  • #11 21673761
    Joel Funk
  • Low-side N-channel switch reduces gate drive voltage
    #12 21673762
    Pieter Kruger
The discussion focuses on selecting suitable MOSFETs for controlling 12V solenoids using 3.3V logic from a Spark Core development board. A logic-level N-Channel MOSFET such as the BS-170 is recommended for low-voltage gate drive compatibility. The MOSFET should be connected as a high-side or low-side switch depending on the circuit design, with the low-side configuration often preferred for easier gate drive at 3.3V. A flyback (Schottky) diode across the solenoid terminals is essential to protect the MOSFET from voltage spikes caused by the inductive load when switching off. Proper grounding practices are critical to avoid noise and power dropouts, including separating high-current and low-current grounds and possibly adding a capacitor across the solenoid supply. The BS-170 can handle continuous currents up to about 500 mA; for solenoids drawing higher current, a MOSFET with a higher current rating is necessary. Users should verify MOSFET pinouts carefully to avoid wiring errors. Additionally, pre-assembled driver modules, such as those available from SparkFun, can simplify implementation.
TL;DR: Use a logic‑level N‑MOSFET (e.g., BS170: ~500 mA continuous, ~1.2 A pulse). “Make sure the ground of the solenoid power supply is connected to the ground of your Spark Core power supply.” This setup works with 3.3 V control and a higher solenoid voltage. [Elektroda, Screaming Circuits, post #21673753]
Why it matters: This FAQ helps makers drive 6–12 V solenoids from 3.3 V GPIO safely and reliably, avoiding blown parts and noise issues.
What MOSFET works best to drive a 12 V solenoid from 3.3 V logic?
Use a logic‑level N‑channel MOSFET. The thread recommends BS170 as an accessible option for 3.3 V GPIO control of small coils. If your solenoid current is higher, select a MOSFET with a larger continuous current rating. [Elektroda, Screaming Circuits, post #21673752]
How should I wire the MOSFET—high‑side or low‑side?
Use the N‑MOSFET as a low‑side switch. Put the solenoid between +V and the Drain, and connect the Source to ground. This keeps the required gate‑to‑source voltage low and ensures full enhancement from a 3.3 V GPIO. [Elektroda, Pieter Kruger, post #21673762]
Why do I need a flyback diode, and what problem does it fix?
When you switch off an inductive load, the collapsing magnetic field generates a high reverse‑voltage spike (back‑EMF). That spike can destroy the MOSFET. A flyback diode provides a safe path for this current and protects the switch. “You need a flyback diode anytime you switch an inductive load.” [Elektroda, Screaming Circuits, post #21673757]
How do I orient the flyback diode across the solenoid?
Place the diode directly across the solenoid terminals. Connect the anode to ground and the cathode to the MOSFET/solenoid positive side. It looks reversed in normal operation, but it conducts only during turn‑off to clamp the spike. [Elektroda, Screaming Circuits, post #21673752]
What current can a BS170 handle, and what if my coil draws more?
BS170 supports about 500 mA continuous and around 1.2 A in brief pulses. If your solenoid’s hold current exceeds ~250 mA margin, choose a MOSFET with a higher continuous rating and lower RDS(on). That reduces heating and improves reliability. [Elektroda, Screaming Circuits, post #21673753]
Can I power the solenoid from a separate 6–9 V supply and still use 3.3 V control?
Yes. Drive the MOSFET gate from the 3.3 V GPIO, power the solenoid from its own supply, and tie the grounds together. “Make sure the ground of the solenoid power supply is connected to the ground of your Spark Core power supply.” [Elektroda, Screaming Circuits, post #21673753]
How do I reduce noise and protect my microcontroller board?
Do not mix high‑current and logic grounds in the same traces. Route coil current separately, then join grounds at a single point. Add a decoupling capacitor across the relay/solenoid supply to tame transients and dips. [Elektroda, richard gabric, post #21673758]
Why is my MOSFET only showing ~0.5 V on the output when I turn it on?
Check the MOSFET pinout against the datasheet. Some parts flip the usual Gate‑Drain‑Source order, causing miswiring and weak conduction. Correct pin mapping typically restores full switching behavior. [Elektroda, Screaming Circuits, post #21673760]
Is the control signal considered active‑high or active‑low in this setup?
With the suggested N‑MOSFET low‑side switch and pulldown on the gate, a logic high at the GPIO turns the solenoid on. A logic low turns it off. That’s an “Active High” configuration. [Elektroda, Screaming Circuits, post #21673752]
What gate resistor or pulldown do I need?
Include a gate‑to‑ground resistor so the MOSFET stays off during reset or boot. Connect the GPIO to the gate, and the pulldown to ground. This prevents accidental activation from a floating gate. [Elektroda, Screaming Circuits, post #21673752]
Can I buy a ready‑made driver board instead of wiring parts?
Yes. The SparkFun MOSFET power driver board integrates the MOSFET and protection parts, matching the thread’s guidance. It simplifies wiring and reduces common mistakes for beginners. [Elektroda, Joel Funk, post #21673761]
Will a 9 V coil supply work with the Spark Core’s 3.3 V GPIO?
Yes, if you use the MOSFET as a low‑side switch and share grounds. One participant confirmed planning a +9 V solenoid while keeping 3.3 V logic control. Add the flyback diode for protection. [Elektroda, Luke Weston, post #21673755]
Any quick wiring steps for a low‑side N‑MOSFET driver?
  1. Connect solenoid between +V and MOSFET Drain.
  2. Connect MOSFET Source to ground; tie logic and coil grounds together.
  3. Drive Gate from 3.3 V GPIO; add gate pulldown and a flyback diode across the solenoid. [Elektroda, Pieter Kruger, post #21673762]
What’s an edge case that can still bite me even with a diode?
If the MOSFET is mis‑pinned on your board, it can half‑turn‑on and show a small voltage, misleading debugging. Always confirm the package pinout before powering. “Double check the pin‑out in the datasheet.” [Elektroda, Screaming Circuits, post #21673760]
Do grounding practices affect reliability as much as parts choice?
Yes. Poor ground routing can inject switching spikes into the micro, causing resets or sensor glitches. Keep high‑current return paths away from logic returns and use local supply decoupling near the coil. [Elektroda, richard gabric, post #21673754]
