How to Identify and Rewire a 1994 French Tennis Stringing Machine Transformer for 220V?
372 8
  • Need transformer wiring details for 220V conversion
    #1 21676629
    D S
  • #2 21676630
    Kevin Angelo Ma
  • #3 21676631
    D S
  • Series-wire the dual primary for 230V AC
    #4 21676632
    richard gabric
  • Asking how to test transformer rewiring safely
    #5 21676633
    D S
  • Inductance test to verify transformer winding phasing
    #6 21676634
    richard gabric
  • Series-wiring the primaries for 220V input
    #7 21676635
    D S
  • Series-linking primaries for correct 220V phasing
    #8 21676636
    richard gabric
  • Correct transformer link between E2 and S1
    #9 21676637
    richard gabric
A 1994 French tennis stringing machine transformer originally wired for 120V in the US needs to be rewired for 220V use in Hong Kong. The transformer has two primary windings currently connected in parallel for 110-120V operation, with links between terminals E1 & E2 and S1 & S2. To convert for 220-240V, the windings must be connected in series by removing these parallel links and creating a new link between E2 and S1, while connecting the brown wire to E1 and the blue wire to S2. Correct phasing is critical; the start and end of each winding must be properly linked to avoid open circuits or incorrect voltage output. Testing winding resistance with a multimeter can verify similarity between windings, and an inductance meter can confirm correct phasing by measuring inductance changes when windings are in series versus parallel. Incorrect wiring or phasing results in no machine operation or improper voltage transformation. Care must be taken to avoid overheating solder joints or damaging the bobbin during rewiring.
