Aston Martin DB9 Tail Light 2007 PCB: Identify S1J S63 Marked IC and Replacement Sources
312 7
  • #1 21677679
    Kevin Angelo Ma
  • Identifying S1J S63 chip in DB9 tail light PCB
    #2 21677678
    Phuong Tran
  • #3 21677680
    Phuong Tran
  • #4 21677681
    Richard Shadbolt
  • #5 21677682
    Phuong Tran
  • Series components are likely diodes, not the LED
    #6 21677683
    Richard Shadbolt
  • Scrape pad surface to restore two-terminal connection
    #7 21677684
    Justin Spencer Mamaradlo
  • Check for bloated capacitors and use a temperature-controlled iron
    #8 21677685
A 2007 Aston Martin DB9 tail light PCB controlling LEDs has suffered water damage causing short circuits and component failure. The damaged chip marked "S1J S63" is likely a diode, possibly an S1J diode, commonly used in series with LEDs for current protection up to 1A. The PCB pads were damaged and lifted during component removal, complicating repair. Recommendations include verifying component identity by checking for diode polarity markings (a bar at one end), testing components with a multimeter, and inspecting capacitors for damage such as bloating. Repair strategies involve careful soldering with a temperature-controlled iron, reconstructing damaged PCB tracks by scratching the pad surface to create new connections, or using prototype boards to bypass lifted tracks. Replacement components like diodes and capacitors are generally easy to source once identified. High-resolution images are needed for precise identification of components.
