Amperis Battery Rectifier Charger for Industrial Use—Is It Reliable?
369 6
  • #1 21677996
    Gustavo Cedron
  • #2 21677997
    Rick Curl
  • #3 21677998
    Gustavo Cedron
  • #4 21677999
    Rick Curl
  • #5 21678000
    Gustavo Cedron
  • Modular rectifier recommendation for better redundancy
    #6 21678001
    Rick Curl
  • #7 21678002
    Gustavo Cedron
A company is seeking a reliable battery rectifier charger for industrial use, specifically for a 48V DC, 200A system with gel batteries requiring fast charging, intended for a telephone central office application. The Amperis ASR rectifier solution was identified as a promising option. Feedback highlighted the suitability of the Amperis rectifier but also recommended considering modular rectifiers composed of multiple smaller units in parallel to enhance failure tolerance and scalability. An example of such a modular rectifier is the DPR4000B from Delta Power Solutions, which, although designed for single-phase input, has three-phase variants available. The discussion emphasizes evaluating system requirements and exploring modular designs for improved reliability and future expansion.
