Logitech Illuminated Keyboard Not Working After PC Hibernation—USB Port Issue?
285 9
Why does my Logitech illuminated USB keyboard stop working after the PC resumes from hibernation until I unplug and reconnect it?
The issue is more likely Windows/USB wake handling than a USB port needing a “kick-start”; the PC may not be re-scanning the keyboard properly when it comes out of hibernation [#21678436] Check Device Manager for the USB keyboard and make sure the Power Management option “Allow this device to wake computer” is enabled [#21678440] Also verify that “Allow computer to turn off this device to save power” is unticked, or left greyed out as on some systems [#21678440] One suggested workaround was trying the keyboard through a powered USB hub, but the thread’s main technical advice was to review the keyboard’s wake/power settings rather than assume the port lacks current [#21678439][#21678440]
  • Powered USB hub suggested for resume issue
    #1 21678435
    Alan Winstanley
  • #2 21678436
    PeterTraneus Anderson
  • #3 21678437
    Alan Winstanley
  • #4 21678438
    Alan Winstanley
  • #5 21678439
  • #6 21678440
    Ian Stedman
  • #7 21678441
    Alan Winstanley
  • Enable USB keyboard wake in device manager
    #8 21678442
    Jason Karlaile
  • #9 21678443
    Alan Winstanley
  • #10 21678444
    Jason Karlaile
A Logitech illuminated USB keyboard fails to reconnect automatically after a PC resumes from hibernation, requiring manual unplugging and re-plugging. The issue may stem from the USB port not reinitializing power or failing to rescan USB devices upon wake. Bus-powered USB ports typically supply up to 500 mA at 5 V, with hubs delivering up to 100 mA per port, which may affect device power-up. Windows device manager settings under the Power Management tab are critical: enabling "Allow this device to wake the computer" and disabling or ensuring "Allow the computer to turn off this device to save power" is unticked or greyed out can influence device behavior. Some users report that connecting the keyboard through a powered USB hub can resolve the problem. The problem appears common among Logitech illuminated keyboard users, suggesting a combination of USB power management and device wake settings as the root cause.
