Hand-cranked dynamo alternative to Shutter Precision SV-9 for LED lighting system
291 6
  • Seeking a hand-cranked dynamo substitute for SV-9
    #1 21680792
    Michelle OBrien
  • Permanent-magnet DC motors as hand-cranked dynamos
    #2 21680793
    Rick Curl
  • Rectified dynamo output fed to buck-boost module
    #3 21680794
    Michelle OBrien
  • Stepper motor with bridge rectifiers as generator
    #4 21680795
    Rick Curl
  • Hand-cranked torches and gearing suggested
    #5 21680796
    David Ashton
  • Geared-up stepper motor suggested for hand-cranked generator
    #6 21680797
    Julian Edgar
  • #7 21680798
    Alan Winstanley
The discussion centers on finding a hand-cranked dynamo alternative to the Shutter Precision SV-9 hub dynamo for powering an LED lighting system as described in Julian Edgar's article in Everyday Practical Electronics magazine. The required electrical specifications include an input voltage range of approximately 3 to 32 V and a maximum current of about 1 A, feeding a DC/DC buck-boost converter outputting 1.25 to 35 V. Several suggestions highlight that any permanent-magnet brushed DC motor can function as a dynamo, and small stepper motors, especially bipolar types with four wires, are effective generators when combined with appropriate rectification using bridge rectifiers and Schottky diodes for efficiency. Hand cranking will likely require gearing or pulleys to achieve sufficient rotational speed for adequate voltage and current output. Alternatives such as repurposed motors from old printers (e.g., NEMA 17 stepper motors), hand-cranked torches, or even steam-powered setups using small DC motors or sterling engines were proposed. The Shutter Precision SV-9 is noted for its low drag and high efficiency, making it challenging to match with generic motors without gearing or specialized design.
