How to Connect 4-Pin Common Anode RGB LEDs to PC Case with 12V PSU and Controller?
294 5
  • Need parallel wiring and current limiting resistors
    #1 21681186
    can yuan
  • Common-anode RGB LEDs need 500 ohm resistors
    #2 21681187
    Max Maxfield
  • Increasing resistor value to dim RGB LEDs
    #3 21681188
    Rick Curl
  • No resistors needed for one common-anode RGB LED
    #4 21681189
    Rick Curl
  • #5 21681190
    Cologne LED
  • #6 21681191
    Rick Curl
