How to Monitor 120V/20A (NEMA 5-20P) Lab Equipment With 220V/20A Power Meters?
312 8
  • Use a 120V/20A meter or current transformer
    #1 21683055
    Jennifer Ballew
  • Suggests checking load current and contacting Boss for options
    #2 21683056
    David Ashton
  • Spam QuickBooks support advertisement
    #3 21683057
    Marshall maxx
  • Using a transformer to adapt 120V loads to 220V meters
    #4 21683058
    Jennifer Ballew
  • Use a 5000 VA transformer for 110 V at 40 A
    #5 21683059
    Aubrey Kagan
  • Suggesting transformer losses and meter modification options
    #6 21683060
    David Ashton
  • #7 21683061
    Erin Preso
  • #8 21683062
    asha negi
  • 5000VA transformer suggested for 120V monitoring
    #9 21683063
    nilee thoumus
The discussion addresses the challenge of monitoring 120V/20A lab equipment with power meters designed for 220V/20A (NEMA 6-20P) and 120V/15A (NEMA 5-15P) devices. The main issue is that some lab equipment uses NEMA 5-20P plugs for 120V circuits capable of 20A, which do not match the available power meters. Using a 120V/15A meter on 20A equipment risks damage, and direct adaptation is discouraged by the manufacturer. Suggested solutions include consulting the manufacturer (Boss Controls) for possible special orders or custom adapters. Another technical approach involves using transformers to step voltage up or down to match meter requirements; however, transformers capable of handling 5000VA (e.g., 220V/20A to 110V/40A) are large, heavy, costly, and inefficient (5-10% power loss). Wiring custom transformer setups requires expert knowledge and adherence to safety and legal standards. The consensus emphasizes caution due to electrical hazards and the complexity of creating suitable adapters or transformer configurations for accurate power monitoring of 120V/20A equipment using 220V/20A meters.
