How to Monitor 120V/20A (NEMA 5-20P) Lab Equipment With 220V/20A Power Meter?
495 9
How can I monitor 120V/20A lab equipment with a power meter rated for 220V/20A and a NEMA 6-20P plug?
Use the 220V meter ahead of a step-down transformer feeding the 120V/20A load, rather than trying to put a 120V/15A meter directly in line. A transformer sized for the full 220V/20A case would be about 4400 VA and very large, but for a 110V/20A load you only need about a 2200 VA transformer, roughly 220V/10A in and 110V/20A out [#21684868] This setup will let the meter measure the supply side power, not the load-side current and voltage, and transformer losses will also show up in the reading [#21684868] If your goal is just power consumption, it should be a fairly good measure [#21684868]
  • Use a 120V 20A meter or current transformer
    #1 21684867
    LennoxConner LennoxConner
  • Using a 220 V meter with a step-down transformer
    #2 21684868
    John David Heinzmann
  • Using a 120V/20A meter with 5-20P loads
    #3 21684869
  • #4 21684870
  • #5 21684871
    anilreddy
  • #7 21684873
    Spice Agent
  • #8 21684874
    philcollin
  • #9 21684875
    philcollin
  • #10 21684876
    philcollin
The discussion addresses the challenge of monitoring power usage of 120V/20A lab equipment with a power meter rated for 220V/20A (NEMA 6-20P). The lab equipment uses NEMA 5-20P plugs for 120V circuits capable of 20 amps, but the available power meters are either 220V/20A or 120V/15A, making direct monitoring problematic. Using a 120V/15A meter risks damage due to the higher current draw. A proposed solution involves placing the 220V/20A power meter on the supply side of a step-down transformer that converts 220V to 110V at 20A. This requires a transformer rated around 2200 VA (110V/20A output, 220V/10A input). However, such transformers are large, heavy, and costly. Additionally, power losses in the transformer will affect the accuracy of the power meter readings, as the meter measures input side parameters rather than the load side. The discussion also references medium power transformers as potential options but notes affordability and practicality concerns.
