Wiring 3 Switches to Control 1 24V DC Outdoor Beacon/Light with Relays
327 7
  • #1 21683088
    wayne singleton
  • Clarifying switch logic, load current, and wiring details
    #2 21683089
    Rick Curl
  • Three switches need latching relay control
    #3 21683090
    wayne singleton
  • Three switches in parallel for beacon control
    #4 21683091
    Rick Curl
  • Clarifying three-switch layout for delivery beacon control
    #5 21683092
    wayne singleton
  • Safety warning: verify lockout tagout requirements
    #6 21683093
    Elizabeth Simon
  • Recommend 12 V alarm parts and explosion-proof switches
    #7 21683094
    Rick Curl
  • #8 21683095
    wayne singleton
The discussion addresses wiring three outdoor toggle switches to control a single 24V DC beacon/light, allowing any switch to activate the beacon independently, with the beacon remaining on until all switches are off. The beacon is intended for a delivery indication system outside a building with bulk tanks, where entry is restricted during deliveries. The recommended wiring involves connecting three single-pole switches in parallel to the positive line of the 24V supply, with the beacon connected between the switches and the negative supply. For a small LED beacon, no relay or controller is necessary, but a current-limiting resistor is required if building the beacon from individual LEDs. Considerations include using appropriate wire gauge (e.g., 0.75mm²), ensuring the switches and beacon are rated for outdoor use, and possibly explosion-proof components if hazardous atmospheres are present. Safety concerns suggest verifying compliance with lockout/tagout procedures and potentially using lockable switches or dual indicator systems. A suggestion was made to consider 12V systems common in burglar alarms for easier sourcing of strobes and power supplies. The Seco-Larm brand was mentioned as a source for LED strobes and xenon flash tube strobes suitable for such applications.
