SSDP Discovery in OpenBeken - make your IoT device visible by Windows in local network places
p.kaczmarek2 2607 0
  • OpenBeken devices can use SSDP (Simple Service Discovery Protocol) to become discoverable on a local area network.
  • The setup needs no central server, no MQTT connection, and no Home Assistant, so Windows can find OBK instances in the “Local Network Places” tab.
  • A step-by-step guide shows how to enable SSDP on OBK and demonstrates discovery working in practice, which is handy for small IoT setups with a few devices.
📢 Listen (AI voice):
  • SSDP Discovery in OpenBeken - make your IoT device visible by Windows in local network places
    SSDP (Simple Service Discovery Protocol) can be easily enabled on OpenBeken devices to make them discoverable by other machines on your local area network. No central server is needed for this purpose, no MQTT connection and no Home Assistant is required. Enabling SSDP can make your Windows machines detect OBK instances in the "Local Network Places" tab. Here's a step by step guide showing how to enable SSDP on OBK and how it works in practice:
    As you can see, SSDP can be very useful, especially if you are just starting the adventure with IoT and have just a few OBK devices. Having all your devices listed on Windows can be very handy.
    Thank you for watching. Let us know if you have any questions, we will try our best to help you.
    p.kaczmarek2 wrote 14728 posts with rating 12814, helped 659 times. Been with us since 2014 year.
TL;DR: With 0 central servers and 0 MQTT connections, "No central server is needed" to make OpenBeken devices visible on a local network. This FAQ helps Windows and IoT beginners enable SSDP so OBK devices appear in Local Network Places without Home Assistant. [#20684656]
Why it matters: It gives small OpenBeken setups a simple, local-first way to find devices from Windows without extra infrastructure.
Option Needed for Windows Local Network Places discovery Stated in the thread
SSDP on OpenBeken Yes Enabled on the device
Central server No Not needed
MQTT connection No Not required
Home Assistant No Not required
Key insight: SSDP turns OpenBeken discovery into a direct LAN feature. For a few devices, that is often the fastest way to see them on Windows. [#20684656]
  • The post says SSDP stands for Simple Service Discovery Protocol and uses the local area network so devices can be discovered by other machines without a central service. [#20684656]
  • The guide explicitly removes 3 dependencies for discovery: 0 central servers, 0 MQTT brokers, and 0 Home Assistant instances. [#20684656]
  • Windows can detect OpenBeken instances in 1 specific view: Local Network Places. That makes device visibility practical for everyday desktop use. [#20684656]
  • The forum post was published on 2023-08-07 at 14:33:42 +02:00, so the documented workflow is a dated, reproducible setup reference. [#20684656]
1. What is SSDP and how does it help OpenBeken devices become discoverable on a local network?
SSDP helps OpenBeken devices announce themselves so other machines on the same local network can find them. "SSDP is a discovery protocol that lets devices advertise services on a local network, without a central controller." In this post, enabling SSDP makes OBK instances discoverable by Windows in Local Network Places, so the device becomes easier to find on a LAN. [#20684656]
2. How do I enable SSDP on an OpenBeken device so it shows up in Windows Local Network Places?
Enable SSDP on the OpenBeken device and place it on the same LAN as the Windows PC. The thread presents this as a step-by-step workflow. 1. Turn on SSDP in OpenBeken. 2. Connect the device to your local network. 3. Open Windows Local Network Places and check for the OBK instance. The post says this process works without MQTT or Home Assistant. [#20684656]
3. Why doesn't SSDP on OpenBeken require a central server, MQTT broker, or Home Assistant to discover devices?
It does not require them because the discovery happens directly on the local area network. The post states three separate exclusions: no central server, no MQTT connection, and no Home Assistant. That means OpenBeken can expose device presence through SSDP alone, which keeps discovery local and simpler for small installations. [#20684656]
4. What is OpenBeken and what kinds of IoT devices can use its SSDP discovery feature?
OpenBeken is the firmware platform referred to in the post, and the thread says its devices can use SSDP discovery. "OpenBeken is IoT device firmware that can expose network features locally, including SSDP-based visibility on a LAN." The post does not list exact product categories, models, or chipsets, so it only supports the broader claim that OpenBeken devices can be made discoverable. [#20684656]
5. How does Windows detect OpenBeken instances through SSDP in the Local Network Places view?
Windows detects them by seeing the SSDP-advertised OpenBeken instance on the same local network. The post names one Windows destination directly: Local Network Places. Once SSDP is enabled on the OBK device, Windows can list that instance there, which gives you a visual way to locate the device without extra software. [#20684656]
6. What steps should I follow to make my OpenBeken IoT device visible to other machines on the same LAN?
Use SSDP on the device and keep discovery inside the same LAN. A simple 3-step path follows the thread closely. 1. Enable SSDP on the OpenBeken device. 2. Make sure the device is on your local area network. 3. Check from another machine, such as Windows, for the OBK instance in Local Network Places. The post frames this as beginner-friendly for small setups. [#20684656]
7. Why might an OpenBeken device with SSDP enabled not appear in Windows Network or Local Network Places?
The thread only supports one concrete cause: the device may not be discoverable on the same local area network. It does not provide a router, firewall, or Windows troubleshooting checklist. If the OBK instance does not appear, the safe thread-based conclusion is that SSDP visibility on that LAN has not been achieved yet, even though the guide says it can work in Windows Local Network Places. [#20684656]
8. Which Windows versions and network settings are most important for seeing SSDP-discovered OpenBeken devices?
The post identifies Windows and Local Network Places, but it does not name any Windows version or setting. The only explicit requirement is local-network discoverability after SSDP is enabled on the OpenBeken device. So the strongest supported answer is that a Windows machine on the same LAN is the key condition described in the thread. [#20684656]
9. How does SSDP discovery in OpenBeken compare with MQTT or Home Assistant for finding devices on a home network?
SSDP is presented as the simpler path for finding devices because it works without MQTT and without Home Assistant. The post makes that contrast explicit by removing two common platform dependencies and one infrastructure dependency. For discovery alone, SSDP gives OpenBeken a direct LAN-based method, while MQTT and Home Assistant are not required for the device to appear in Windows Local Network Places. [#20684656]
10. What practical advantages does SSDP give beginners who only have a few OpenBeken devices?
It gives beginners an easy way to see devices listed in Windows without building extra infrastructure. The post specifically says SSDP is very useful when you are just starting with IoT and have only a few OBK devices. In that scenario, having all devices listed on Windows can be very handy, because discovery stays local and simple. [#20684656]
11. What is the difference between SSDP device discovery and controlling OpenBeken devices through Home Assistant automation?
SSDP discovery makes the device visible on the local network, while the thread does not describe Home Assistant automation control at all. The post only states that Home Assistant is not required for discovery. So the supported difference is narrow but clear: SSDP handles visibility in Windows Local Network Places, and the thread gives 0 automation steps, rules, or control flows for Home Assistant. [#20684656]
12. How can I verify that SSDP is actually running and announcing correctly on my OpenBeken device?
Check whether Windows can detect the OBK instance in Local Network Places after SSDP is enabled. That is the only verification method stated in the thread. If the device appears there, the guide’s practical outcome has been met. The post also points to a video demonstration, which shows how the process works in practice on a real setup. [#20684656]
13. What common router or firewall issues can block SSDP discovery of OpenBeken devices on a local network?
The thread does not name any router or firewall issue, so it does not support a specific block list. What it does support is the boundary condition: discovery happens on the local area network. If SSDP discovery fails, the thread-based takeaway is only that local-network visibility has not been achieved, not which network component caused it. [#20684656]
14. How should I troubleshoot local network visibility when one computer sees my OpenBeken device but another one does not?
Use the computer that sees the device as the reference and confirm the other computer is checking the same Windows view: Local Network Places. The thread does not give a full troubleshooting tree, but it ties success to SSDP visibility on the local area network. So the supported action is to confirm both machines are trying to discover the same OBK instance on that LAN after SSDP was enabled. [#20684656]
15. What security and privacy considerations should I keep in mind when making OpenBeken devices visible through SSDP on my LAN?
The main consideration supported by the thread is scope: visibility is described on the local area network, not through a central server. That local-only discovery model limits the feature to LAN presence in the post’s description. The thread does not discuss authentication, encryption, access control, or privacy risks, so no stronger security claim is supported by this source alone. [#20684656]
