GreenSun SEW1080 Smart Power Strip Wi-Fi Module BEKEN Chip Connectivity Issues
Edgar24 1161 1
Treść została przetłumaczona german » english Zobacz oryginalną wersję tematu
  • BK7231M module likely needs preprogrammed replacement
    #1 21767990
    Edgar24
    Hello to the experts.
    My name is Werner. I am looking for a solution to the following problem:
    I have 2 GreenSun Wi-Fi Smart Power Strip sockets with night light (which is very important to me!).
    While the 2nd one works without any problems, the 1st one gives me almost sleepless nights. It constantly loses the connection to the Wi-Fi, sometimes after about 10 minutes, sometimes after several hours.
    If I disconnect it from the network for a while, I can set it up again. Then the game starts all over again.
    After several tests, including with cold spray, and many more in-depth considerations, I came to the realisation that it was most likely a "defective" Wi-Fi module.
    So I finally unsoldered the part. The photos are attached here.
    If I'm reading this correctly, the chip has the following designation according to the sticker: Geensun-SEW1080 _ 3dcc37b9 _ B6C4E7 _ 2023-06-12
    On the back of the module: E491226
    I then removed the aluminium cover to get to the chip: It is a BEKEN BK7231M _ F03070X0 (or XQ?)
    But as I have no idea about these modules, I could imagine getting them from Ali (or elsewhere???).
    Can I, assuming they have the same designations, solder them in and everything will work again?
    Or, in the worst case, do they have to be programmed beforehand, and I have no idea how to do that.
    It would be very helpful if someone could take on my case.
    Best regards from the Ruhr area
    Werner
    GreenSun smart Wi-Fi socket on a grid measurement mat. Back view of GreenSun WiFi Smart Power Strip plug with technical data and QR code. Disassembled GreenSun Wi-Fi Smart Power Strip showing internal electronics BK7231M Wi-Fi module inside GreenSun power strip case held in hand
    Close-up of GreenSun smart power strip PCB showing electronic components and wiring. Round GreenSun PCB with wires, capacitors, and LEDs, placed on a technical cutting mat. Circuit board from GreenSun power strip with relay, button, and LEDs arranged in semicircle Wi-Fi module on PCB labeled SEW108S-WiFi REV1.1 shown from above
    BK7231M Wi-Fi module on a blue PCB with labeled signal pins and contact pads Wi-Fi module GreenSun-SEW1080 with label, QR code, and solder pins visible BK7231M CB2S Wi-Fi module on purple background, showing pins and labels
  • Module firmware must match device GPIO configuration
    #2 21769606
    Rate: 12881
    Any Wi-Fi module of this type must be programmed with a batch configured for the device. Buying a blank module, or taking a module from another device, will not help - devices have different GPIO configurations and functionality.
    If you don't care about cloud connectivity, you could try uploading OpenBeken there:
    Theoretically you could buy a second CB2S, rip the flash from your CB2S, and upload that flash to the new CB2S, but I don't know how much that will help, because if the error is in the configuration, you'll take that error along with a copy.
    By the way... BK7231M, rare, usually there is a BK7231N in the CB2S, and the batch from BK7231M will not run on BK7231N. So another problem. It's unlikely you'll buy a replacement with a BK7231M.
