S1 switching contact does not work for switch with CBU module and PIN assignment
flakerazor 684 0
This content has been translated flag-de » flag-en View the original version here
  • No reaction on pin 26 for S1 input
    #1 21789200
    flakerazor
    i have flashed this switch 4 times, but unfortunately the S1 switch contact does not work with the PIN assignment.
    https://www.elektroda.com/rtvforum/topic4099102.html#21393164
       "rl1_lv":"1",
       "on_off_cnt":"10",
       "onoff_rst_m":"1",
       "onoff_clear_t":"10",
       "rand_dpid":"42",
       "net_trig":"4",
       "onoff_n":"5",
       "netled1_lv":"1",
       "jv":"102",
       "onoff_rst_type":"2",
       "total_bt_pin":"24",
       "nety_led":"0",
       "over_cur":"20000",
       "total_stat":"2",
       "reset_t":"3",
       "netled1_pin":"9",
       "chip_type":"3",
       "lose_vol":"40",
       "remote_add_dp":"49",
       "remote_list_dp":"50",
       "net_type":"0",
       "over_vol":"300",
       "inch_dp":"44",
       "module":"CBU",
       "ch_cddpid1":"9",
       "onoff1":"26",
       "clean_t":"6",
       "init_conf":"38",
       "zero_select":"0",
       "onoff_type":"0",
       "series_ctrl":"2",
       "total_bt_lv":"0",
       "cyc_dpid":"43",
       "remote_select":"0",
       "ch_num":"1",
       "rl1_pin":"20",
       "ele_rx":"10",
       "netn_led":"0",
       "vol_def":"0",
       "ch_dpid1":"1",
       "ele_tx":"11",
       "crc":"118"
    AI: Which exact switch model and which firmware version is involved?
    Girier Smat Switch 1 gear
    AI: How exactly is the S1 switch contact connected and what exactly happens when you actuate it (e.g. no reaction, malfunction, error message)?
