SAECO Magic M2 - Error 308 "Coffee water circuit clogged"
bfiorentini892 1029 0
  • Pump runs but no water reaches brew unit
    #1 21806323
    bfiorentini892
    I just bought a used SAECO Magic M2, which is an entry-level professional machine for small offices/hotels.
    I paid it a third of the original price because it gives an error when starting up: E308: Coffee water circuit clogged.
    I'm suspecting a faulty/clogged valve in the coffee water circuit but I'm not sure. The machine is pretty hard to disassemble so I want to be sure about the problem before trying to do it.
    I managed to find a temporary workaround for the error: unplugged the pump (Ulka EP5GW) from the water tank and let it take water directly from a water basin under it. The priming goes fine and I'm able to access the beverages selection menu, but when I select any beverage the following happens: the grinder works, the brew unit activates, the pump starts working, but nothing comes out.
    Anyone experiencing similar issues or have any experience with this machine model?
    Thank you
