Tuya W509Z1 RGBCT Bulb Compatibility with Cloudcutter Exploit on Firmware 1.0.0
tadeu1 561 2
  • Cloudcutter exploit may not support firmware 1.0.0
    #1 21835151
    tadeu1
    I have this bulb W509Z1
    I buy here
    https://pt.aliexpress.com/item/10050072549962...in.77.20f9caa4zlyBHD&gatewayAdapt=glo2bra
    and it have 1.0.0 and mcu 1.0.0
    But I think this exploit its not for my version, is it possible to add the version 1.0.0, its hard to take out the pcb from light because the wire in the bottom
    https://github.com/tuya-cloudcutter/tuya-clou...s/tuya-generic-1947z5r-w509z1-rgbct-bulb.json
    Ubuntu screen with terminal logs for scanning Tuya SmartLife AP and running tuya-cloudcutter
  • CloudCutter compatibility depends on SDK and chipset, not 1.0.0
    #2 21835392
    k45i89o98j66
    Help: 538
    Rate: 991
    CloudCutter exploits a 'vulnerability' in the Tuya software of older devices that:
    accept unauthorised OTAs,
    do not have the newer Tuya SDK security features,
    allow device profile and firmware to be uploaded without a signature.
    Vulnerability does not depend on version "1.0.0" in general - only on:
    🔹 the version of the Tuya SDK used in the compilation,
    🔹 the specific chipset (BK7231T/BK7231N/RTL8720CF),
    🔹 the list of available profiles for the device in question.
    Added after 1 [minute]:
    CloudCutter is more of a technical exploit / firmware hack
    Added after 47 [seconds]:
    Tuya W509Z1 RGBCT bulb with Cloudcutter exploit on firmware 1.0.0 Yes is not compatible.
  • #3 21836109
    tadeu1
    thanks
    there's Bulb with a easy way to access the point to solder? I have 4, and they are impossible to access without broken the connector wires.
