Reset Knightsbridge CU9KW socket when WiFi won't reconnect, no mains access?
Bestgear 483 1
  • Front-switch reset for Knightsbridge CU9KW sockets
    #1 21883327
    Bestgear
    Hi Guys
    I have several Knightsbridge CU9KW Smart 13A double mains sockets across my home.
    Long story short - after Wi-Fi changes in the house (same SSID and password) - the devices won’t reconnect - seems like they timed out - and are sitting with both RED LEDS flashing.
    Is there any way to reset them from the front switches rather than powering off the ring mains to make them reboot?
    I have no reason to think they need reflashed as the only thing changed is Wi-Fi - and as I mentioned the SSID and creds have not changed.
    Any advice most welcome - thanks
  • #2 21883938
    adamjur1
    Help: 772
    Rate: 1003
    And hasn't the encryption changed by the way - used to not find my wifi smart homu elements for this reason....
    Greetings. J.
