Backup WiFi network on devices with OpenBK firmware - no connection
Adinfo 987 1
  • Backup WiFi never connects on OpenBK devices
    #1 20937848
    Adinfo
    I have quite a few reprogrammed (OpenBK) sockets, switches, thermometers and door open sensors at the moment - I have encountered a problem in them regarding not being able to access a correctly configured second WiFi network (as a backup):
    1. The primary WiFi always connects - I have two separate SSIDs on two routers (one on the first floor and the other in the basement with a different SSID) - I get connection to both as the network is set as primary in the configuration.
    2. The backup WiFi never connects (as the primary is out of range) - I also checked swapping the places of both networks in the configuration, but the symptom is the same - it only connects on the primary, not on the backup.
  • #2 21105132
    Rate: 12809
    Here is a fix, can you check?
    https://github.com/openshwprojects/OpenBK7231T_App/pull/1254
    It's pending final approval before merging into the main releases.
    Long story short, SSID2 was just plain unimplemented before.
