1Gb LAN switch with Home Assistant/ESP32 control for PC Ethernet on/off
Blisk 450 4
  • Disable a switch port from Home Assistant
    #1 21906691
    Blisk
    Is there an option to buy or to make a LAN switch with LAN IN and LAN OUT and with 1 Gb transfer and which can be connected to Home Assistant or maybe it has in ESP32 or something else which can be connected to HA?
    So I can turn on or off that and connect or disconnect LAN to my computer.
    Do you want to buy ready device, or are you also OK with DIY/make it yourself solution?
    I like to buy if exist if not than I will make it.
    Do you want to physically cut the Ethernet link to the PC, or is it enough to disable one switch port from Home Assistant?
    I just need to disable Ethernet connection to work.
  • #2 21906979
    Rate: 12913
    Maybe the simplest way would be to buy a switch and turn it on/off with a smart plug with Tasmota or OBK?
  • #3 21907178
    Blisk
    >>21906979 Yes, that will be the easy way, but I want to hack these which I want.
  • #4 21907663
    proks777
    >>21907178
    I think you need to look into Telnet or API control. I think this is possible on Keenetic routers. Or you could flash the router to OpenWrt. I think AI will help you figure this out.
  • #5 21907665
    Blisk
    >>21906979 Yes, I fugured out that is the simplest way.
