"Hello. I need the USB Forced Upgrade firmware (upgrade_loader.pkg) for a Toshiba 43QA7D63DG Sm
DEISYDANA 24 2
  • Request for Toshiba 43QA7D63DG forced upgrade firmware
    #1 21959185
    DEISYDANA
    "Hello. I need the USB Forced Upgrade firmware (upgrade_loader.pkg) for a Toshiba 43QA7D63DG Smart TV. It is stuck on the boot logo. The mainboard inside is a Vestel 17MB185 (or 17MB180). Thank you."
    @ElektrodaBot "Hello. I need the USB Forced Upgrade firmware (upgrade_loader.pkg) for a Toshiba 43QA7D63DG Smart TV. It is stuck on the boot logo. The mainboard inside is a Vestel 17MB185 (or 17MB180). Thank you."
  • Correct Vestel firmware requires board, panel, and product codes
    #2 21959189
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 372
    Rate: 964
    Initial assessment of available information
    You are asking for a USB forced upgrade package named
    upgrade_loader.pkg
    for a Toshiba 43QA7D63DG Smart TV stuck on the boot logo. The set uses a Vestel platform, and you identify the mainboard as 17MB185 or 17MB180.
    The important point is that for Vestel-based Toshiba/Sharp/Hitachi/JVC/Telefunken/etc. sets, the firmware is not selected only by “17MB185” or “17MB180”. The same board family can be used with different panels, tuners, Wi-Fi modules, NAND/eMMC sizes, bootloaders, regional settings, and brand profiles. A wrong
    upgrade_loader.pkg
    can make the TV worse: no image, inverted colors, wrong backlight control, boot loop, or complete brick.
    Direct answer to the question
    I cannot safely provide a random
    upgrade_loader.pkg
    based only on:
    - Toshiba 43QA7D63DG,
    - mainboard 17MB185 / 17MB180,
    - symptom: stuck on boot logo.
    To identify the correct forced USB firmware, you need to provide at least:
    1. Exact mainboard marking
    - 17MB185, 17MB180, 17MB185S, etc.
    - Board revision if printed, for example
    231xxxx
    235xxxx
    101xxxxx
    , or similar Vestel article/BOM number from the white sticker.
    2. Vestel product code / article number
    - Usually on the rear label or board sticker.
    - Often an 8-digit or longer Vestel code, sometimes starting with
    23...
    or
    10...
    3. Panel model
    - From the sticker on the LCD panel, not from the TV model.
    - Example format:
    VES430...
    LC430...
    T430...
    , etc.
    4. Photo or text from the TV rear label
    - Model:
    43QA7D63DG
    - Serial number / product code / order code / MB code if present.
    Without those details, nobody can reliably choose the correct forced upgrade package.
    Detailed problem analysis
    1. Why “17MB185 firmware” is not enough
    Vestel boards are modular platforms. One board type can appear in many TVs:
    ParameterWhy it matters
    Mainboard typeDetermines SoC, RAM, eMMC/NAND layout, bootloader family
    Board revisionSmall hardware changes can require different firmware builds
    LCD panel typeDetermines LVDS/eDP/V-by-One timing, gamma, mapping, backlight configuration
    Brand/profileToshiba branding, remote codes, CI+, Netflix/DRM settings, region
    Tuner/Wi-Fi moduleWrong firmware may lose tuner, network, Bluetooth or remote functions
    Android/Linux versionBootloader and partition layout must match
    So even if another file is labelled “Vestel 17MB185 Toshiba”, it may not be suitable for your exact 43QA7D63DG.
    2. Difference between normal update and forced upgrade
    Vestel firmware packages are commonly found in two practical forms:
    Firmware typeTypical purpose
    Normal update packageUsed through the TV menu when the TV still boots
    Forced USB package, often
    upgrade_loader.pkg
    Used when the TV does not boot properly and must be recovered from USB
    For a TV stuck at the logo, you need the forced loader package, not just a normal OTA/menu update.
    3. Standard Vestel forced USB upgrade method
    If you obtain the exact matching package:
    1. Use a small USB stick, preferably USB 2.0, 4–16 GB.
    2. Format it as:
    - FAT32
    - MBR partition table
    - one primary partition.
    3. Copy
    upgrade_loader.pkg
    to the root directory of the USB stick.
    4. Disconnect TV from mains.
    5. Insert USB stick into the TV.
    6. Press and hold OK on the original remote control.
    7. While holding OK, connect mains power.
    8. Keep holding until the standby LED starts flashing rapidly or the upgrade process starts.
    9. Release the button and wait. Do not interrupt power.
    10. The process may take several minutes and the TV may reboot automatically.
    On some Vestel sets, a local joystick/button combination may also work, but the remote OK + power-on method is the most common forced update method.
    4. If the TV ignores USB
    If the LED does not start blinking and the TV only remains on the logo, check:
    - USB stick too large or incompatible,
    - USB formatted as exFAT/NTFS/GPT instead of FAT32/MBR,
    - file not in root directory,
    - incorrect filename,
    - wrong package type,
    - wrong USB port,
    - remote not sending correct
    OK
    command,
    - bootloader cannot read USB,
    - corrupted bootloader/eMMC,
    - faulty power rail on the mainboard.
    Try another USB 2.0 stick before assuming the firmware is wrong.
    5. Common fault: eMMC corruption or failure
    A Toshiba/Vestel Android Smart TV stuck on the boot logo often has one of these faults:
    FaultSymptom
    Corrupted Android/data partitionBoot logo loop, recovery may work
    Full internal storageSlow boot, boot loop, app crashes
    eMMC bad blocksRecovery starts but fails/freezes
    eMMC write-protectedFirmware appears to install but fault returns
    Bootloader corruptionNo USB recovery, no proper LED activity
    Power supply instabilityRandom rebooting, incomplete boot
    On 17MB180/17MB185 Android boards, the eMMC is a common suspect. If forced USB recovery fails repeatedly with a confirmed correct package, the next step is usually eMMC diagnosis/reprogramming or replacement, not endlessly trying firmware files.
    Practical guidelines
    Please post clear photos or write the following information:
    Required data
    ItemWhere to find it
    Exact TV modelRear label
    Serial numberRear label
    Product / article / Vestel codeRear label or white sticker on mainboard
    Mainboard full markingPrinted on PCB and white sticker
    Panel modelSticker on LCD panel metal frame
    eMMC markingIC on mainboard, if visible
    Current symptomLogo only, reboot loop, standby LED behavior, backlight status
    Useful example format
    You can reply like this:
    Code: text
    With that data, it becomes realistic to identify whether a matching forced firmware exists and whether the problem is more likely software or eMMC hardware.
    Important warning
    Do not flash firmware from:
    - a different screen size,
    - a different panel code,
    - a different Vestel article number,
    - “similar Toshiba 43 inch” model,
    - generic 17MB185 dump,
    - package from 17MB180 if your board is actually 17MB185, unless confirmed compatible.
    The risk is especially high with QLED/UHD models because panel timing and picture configuration are very specific.
    Brief summary
    You need the exact Vestel/Toshiba forced USB firmware, but the TV model and board family alone are insufficient. Provide the mainboard sticker code, rear label product/article code, and LCD panel model. Also be aware that a boot-logo hang on Vestel Android boards is often caused by eMMC corruption/failure, so even the correct
    upgrade_loader.pkg
    may not repair it if the flash memory is defective.
  • #3 21959190
    DEISYDANA
