Understanding the Purpose of USB Type B Input in Monitors without a Hub
CMS 24983 12
What is the USB Type-B port on a monitor without a USB hub used for?
It is usually a control interface for the monitor, not a hub: with the manufacturer’s software you can adjust the monitor’s image/settings from Windows, and the device may show up as an HID interface device. One reply says this USB link is used to change parameters from the system level with software downloaded from the manufacturer’s website [#2597529] Another gives the same example for a Samsung 765MB, where the USB cable and software are used to adjust monitor settings from the operating system [#2608067]
  • #1 2595308
    CMS
    Help: 258
    Rate: 2602
    I've seen several monitors with a USB type B input but without a hub, recently I came across one, I know what it's for, I plug it in, the system found a new device, the HID interface device, the device has been installed and is ready for use. even in device manager it shows HID device...
    and that's all.
    I still don't know what this USB is for??
  • #2 2595337
    procekkk
    Help: 39
    Rate: 141
    e.g. if you have a USB output on the back of your computer and you want to connect a pendrive (digital, portable hard drives, recorders, etc.) and so as not to mess with the back of the computer, you have a USB input at hand on the top.
    Regards Procekkk
  • #3 2595351
    CMS
    Help: 258
    Rate: 2602
    I'm saying that there is NO USB HUB in this monk, if there was, I wouldn't ask
  • #4 2595553
    Kalik
    Help: 57
    Maybe it's some kind of software interface for this monitor?
  • #5 2595595
    procekkk
    Help: 39
    Rate: 141
    Sorry, my mistake, I didn't read your statement carefully.
    Can you tell me what monitor it is?
    Regards Procekkk
  • #6 2596882
    CMS
    Help: 258
    Rate: 2602
    some NEC, when I get it again I'll tell you exactly, but I emphasize that it's not the first monitor with USB without a hub that I've seen, there was definitely another Samsung
  • #7 2597357
    Bogdanor
    Help: 78
    Rate: 32
    probably to adjust image parameters from Windows, download the appropriate software and that's it, but what else would it be for?
  • #8 2597488
    CMS
    Help: 258
    Rate: 2602
    now something occurred to me, HID interface devices are mainly pointing devices, maybe this monitor responds to touch, I must check it out
  • HID covers more than pointing; USB controls monitor settings
    #9 2597529
    max_gg
    Help: 83
    Rate: 26
    Hello!
    HID is not just pointing devices. The Polish name is "user interface devices".
    They can also be printers - but I haven't seen one compliant with the HID standard yet.
    As for the USB port on the monitor - it is also used to change settings from the system level. All you need is the appropriate software, certainly downloadable from the manufacturer's website.
    Regards!
    Marcin "Max" G.
  • #10 2603459
    nexus2k
    I have a Formac 2010 Gallery 20.1`` monitor which has 2 USB ports on the back of the housing connected to the cable that you connect to the graphics card. Very creative. I connected the receiver of the Logitech LX7 mouse to the USB port on the back of the monitor, so the mouse is only 20-30 cm from the receiver (less battery consumption in the mouse)
  • #11 2603580
    procekkk
    Help: 39
    Rate: 141
    nexus2k: this is not what you mean, CMS friend.
    My CMS friend has only one USB input socket and no outputs.
    Regards Procekkk
  • #12 2608067
    janusz1313
    I have a Samsung 765MB also with a USB cable and together with the appropriate software it is used to adjust the monitor settings from the operating system level...
    Regards
    Janusz
  • #13 2889820
    CMS
    Help: 258
    Rate: 2602
    I feel satisfied with the answer, I'm closing it
The discussion revolves around the purpose of USB Type B inputs on monitors that lack a USB hub. Users note that connecting a USB Type B cable allows the monitor to be recognized as a Human Interface Device (HID), which can facilitate software interactions for adjusting monitor settings directly from the operating system. Some participants suggest that this interface may also support touch functionality or other user interface devices. Specific monitors mentioned include models from NEC and Samsung, with one user referencing a Formac monitor that utilizes USB ports for peripheral connections.
