How to test an alternator on the bench after removing it from the car?
dob12 104162 35
How do I test a removed alternator on the bench with a battery, bulb, and drill?
Connect battery plus to the alternator charging output, battery minus to the housing, and a bulb between battery plus and the charge-lamp terminal; a healthy alternator should make the bulb go out when it is spun fast enough [#3237429] You do need to drive the alternator at the proper speed with the drill unless you can reach that speed another way [#9334915] If the bulb still glows, suspect damaged diodes [#3237429] The diodes can be checked after desoldering the ends of the stator windings [#3237429]
  • #1 3236895
    dob12
    Help: 30
    Rate: 229
    Hello, I'm specifically talking about how to check the alternator removed from the car
    and I do not mean a visual check, because the brushes can be removed and
    check their condition rings as well as strong puncture on the rotor
    or standing also an ordinary meter, but I know that it does a special one
    cable combinations together with the excitation bulb and this connects to the alternator
    together with the battery and the drill drives, if it is ok, the drill decreases
    rotation and the bulb goes out. Please send me this combination diagram
    these cables and connecting them to the alternator, best regards GREG if anyone
    would know links to such pages with descriptions, please share them with me.
    :D
  • #2 3237313
    viper555
    Help: 582
    Rate: 2161
    First, what alternator do you want to check
    grzesiek08
    Rate: 19
    you do not need a diagram, connect the "+" battery to the charging terminal (usually an eight screw or a tip for a thick knector), minus to the body. You connect the bulb between the battery plus and the clamp from the charging lamp and the system is ready. With an efficient alternator, the bulb will go out if it can glow be damaged diode. You can check them, but probably by desoldering the ends of the stator windings. Good luck!
  • #4 3238127
    dob12
    Help: 30
    Rate: 229
    Thanks a lot, that's me, greetings, and as for the type of alternator, I'm just asking, not having any in mind, I am dealing with a mechanic, so I wanted to know. Thanks a lot. :D :D :D
  • #5 4462104
    __daniel__
    Rate: 11
    I have a question about checking the alternator, but a computer-controlled one, i.e. it has a 5-pin connector. (E.g. Mercedes Actros).
    Is it possible to build a circuit, are there maybe schematics?
  • #6 9334801
  • #7 9334915
    macvir
    Conditionally unlocked
    Help: 32
    Rate: 262
    needed, unless you can accelerate the alternator to the right speed yourself :)
  • #8 9335031
  • #9 9338167
    macvir
    Help: 32
    Rate: 262
    wake him up :D
  • #10 9339385
    saly
    Level 32  
    Help: 89
    Rate: 1003
    You gave the bulb.
  • #11 9339702
  • #12 9339801
  • #13 9340121
  • #14 9340197
  • #15 9340614
  • #16 9340636
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    So far, I have not had a case with suspended brushes yet
    It happened to me in cars where the injection pump is above the alternator and diesel was poured into it, after repairing the pump (sealing), the oil dries up and the brush holder is stuck with sludge from brush dust and liquid manure
  • #17 9340642
  • #18 9341506
    miler80
    Help: 272
    Rate: 1395
    There will be even half of the brush, but the spring has no force to push it further and remains torn in the position in which it dried. In sprinter I had that too.
  • #19 9929959
    HarrisonBergeron
    Rate: 21
    How often do the diodes in the alternator get damaged? For a short circuit or a break?
  • #20 9930042
  • #21 9930044
    robert7319
    Help: 12
    Rate: 13
    On short circuit
  • #22 9930048
  • #23 9930092
    robert7319
    Help: 12
    Rate: 13
    Break and open are probably the same.
  • #24 9930221
    HarrisonBergeron
    Rate: 21
    On the skating rink, we most often fall over on the other involved in sliding. ;)
    So I am to understand that both options are equally likely?
    Hmm ... I would rather suspect that the diode burns out for a break.
  • #25 9930296
    viper555
    Help: 582
    Rate: 2161
    There is no rule, but there are conditions
  • #26 9932144
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    And how to classify a diode that behaves normally on the meter and the tested 21W bulb has a break? ;)
    Anyway, what's the difference, when the diode is damaged, how the entire bridge needs to be replaced anyway
  • #27 9932381
  • #28 9933009
    HarrisonBergeron
    Rate: 21
    I am glad that I found a friend. I will not hide that I am counting on your help. So far, no one has been able to provide me with professional advice.
    If possible, I would like to move from the general topic of alternators to a specific example (if necessary, please separate it into a separate thread).
    Where are the excitation diodes in this alternator? (photo)
    This is an alternator from the Ford Mondeo mk2. 3-pin plug. Battery plus - red arrow.
    As for the power diode, the multimeter shows:
    decrease of 0.37 in the conduction direction (body - blue, blue - red),
    and infinity in the reverse direction (red - blue, blue - body).
    Measurement with the voltage regulator removed, but without the bridge rectifier removed. In the photo I marked only 4 blue arrows, but the measurement result is the same regardless of which diode or winding end I measure.
    Now let's get to the things I don't understand:
    What is the connection of the voltage regulator with the bridge marked with the green arrow?
    If this is the output of the excitation diodes, why is there such a solid connection (a thick piece of copper sheet) between the plus and the voltage regulator (red arrow)? The excitation will probably be on this copper connection (???)
    I have looked at many Mondeo alternator diagrams, none match mine, but in some I noticed there is a direct connection of one of the alternator stator windings to the voltage regulator (bypassing the excitation diode). Some controls or something ... I don't know.
    This green connection, maybe that's it? The more that the measurement with the green-blue multimeter gives a result of 0 (in both directions).
    The symptom is that the charging indicator is on in the car and there is no charging.
  • #29 9933038
  • #30 9933421
    HarrisonBergeron
    Rate: 21
    This answer actually dispels my doubts - defective voltage regulator;
    and confirms my suspicion that the excitation diodes are not there - although I have already heard the opinion (car electrician) that the diodes are flooded in this plastic.
    Thanks.
The discussion focuses on methods to test an alternator after it has been removed from a vehicle. Users share various techniques, including connecting the alternator to a battery and using a bulb to check functionality. A specific method involves connecting the positive terminal of the battery to the alternator's charging terminal and the negative to the body, with a bulb connected between the battery and the charging lamp terminal. If the alternator is functioning properly, the bulb will extinguish when the alternator is driven at the correct speed. Additionally, users discuss the importance of checking components like brushes and diodes, and the challenges of testing computer-controlled alternators with specific connectors. The conversation also touches on common issues such as diode failure and the need for proper connections during testing.
TL;DR: 95 % of Bosch alternator failures are traced to the voltage regulator [Elektroda, decybel91, post #9933569]; "You do not need a diagram" [Elektroda, grzesiek08, post #3237429] With a 12 V battery, 21 W lamp and ~1 800 rpm drill you can confirm charge on the bench.
Why it matters: A 10-minute bench test saves hours of reinstalling a dead unit and helps pinpoint whether you need brushes, a regulator or a full rebuild.
• Cut-in speed for most 12 V alternators: 1 500–2 000 rpm rotor (≈3 000–4 000 rpm engine) [Bosch Training, 2018] • Test lamp spec: 12 V, 21 W single-filament bulb (e.g., P21W) [Elektroda, grzesiek08, post #3237429] • Typical regulator price: €30–€180 depending on brand and pin-count [Autodoc Price List, 2023] • 3-pin Denso layout: IG + (ignition), L (warning lamp), S (battery sense) [Elektroda, carrot, post #19608638] • Diode bridge sold as a complete pack; individual diodes rarely stocked [Elektroda, carrot, post #9932144]
How do I bench-test a standard alternator with three terminals?
  1. Clamp the case in a vice and connect B+ to battery positive, case to negative.
  2. Insert a 12 V/21 W bulb between battery + and the small ‘L’ lamp terminal.
  3. Spin the pulley at ≈1 800 rpm with a drill. The lamp should go out and voltage rise above 13.8 V. If the bulb stays lit, check diodes or regulator [Elektroda, grzesiek08, post #3237429]
What rpm do I need to reach for the alternator to excite on the bench?
Most 12 V units start charging once rotor speed exceeds 1 500–2 000 rpm, roughly 25–30 Hz stator frequency [Bosch Training, 2018]. A handheld drill on high gear usually meets this. Below cut-in, the bulb stays lit and voltage stays at battery level.
How is the battery warning lamp wired during a bench test?
Wire one side of the 21 W lamp to battery positive, the other to the lamp (L) terminal. When the alternator’s internal regulator energises, L rises to B+, eliminating current and the lamp goes dark [Elektroda, grzesiek08, post #3237429]
I have a 5-pin, computer-controlled alternator. Can I still bench-test it?
Yes, but you need a programmable field controller or manufacturer schematic. Without LIN/BSSM commands, the regulator may stay at minimal field. Basic lamp-and-battery tests only show bearing or diode faults, not regulation quality [Elektroda, daniel, post #4462104]
How can I tell if an alternator diode is shorted or open?
Using the diode test mode, a healthy diode drops 0.3–0.6 V forward and infinity reverse. A short shows 0 V both ways; an open shows infinity both ways. In Astra CDTi units, technicians saw two open diodes in one bridge [Elektroda, Anonymous, post #9930048]
What causes brushes to hang and stop charging?
Oil or diesel seepage mixes with carbon dust, forming sludge that jams the brush holders. When it dries, springs can’t push the brushes, leaving half their length unused [Elektroda, carrot, #9340636; miler80, #9341506]. Edge case: after pump repair, charging fails because the sludge hardens within hours.
Why does my charge lamp stay on after I changed brushes?
Brush replacement fixes mechanical contact but not electrical faults. A weak regulator, open stator phase or shorted diode will still pull L low, keeping the lamp lit even with new brushes [Elektroda, 9933009–9933038].
Quick 3-step how-to: Replace a bolt-on regulator
  1. Remove two Phillips screws and slide out the old regulator-brush pack.
  2. Blow out carbon dust; inspect slip-rings for grooves.
  3. Install the new pack, torque screws to 1 Nm, and re-test on the bench.
