Smart home – how can you control sockets and lighting remotely?
mischa 141732 244
How should I wire a new house for remote control of lights and power sockets so it is cheap, scalable, and still works manually if the automation fails?
Use a distributed scheme: run an extra low-voltage control bus or a separate low-voltage pair to each socket/switch, and put the relay/triac plus a small microcontroller in the flush-mounted box rather than building one huge relay cabinet [#4660589][#4661044][#4681182] Make every point bypassable or manually switchable so the basic lighting and sockets still work if the automation fails [#4661280] If you want an off-the-shelf platform, Satel INTEGRA 128 was recommended because it expands to 128 inputs and 128 outputs, supports GSM/Ethernet, and can host output modules in DIN rails or junction boxes [#4681182] For a DIY bus, one thread recommends an RS-485-style setup with a separate low-voltage supply over extra cable pairs, and explicitly warns not to use PE or neutral as the automation return [#5502218][#5507705]
  • Clarifying integration needs for whole-house automation
    #241 19415495
    HonestStanley
    Hello everyone,
    I’m building a house and am considering a solution from Sterbox, but I’m not sure how it integrates with other devices, such as the Vaillant Ecotec Plus controller, the heat recovery system, etc.
    It seems they have a well-designed solution for controlling roller blinds – ROLLER BLIND CONTROL FROM A PHONE OR TABLET VIA WiFi (16 blinds)
    Grenton has recently raised its prices again, so I’m considering the best solution.
    I was planning to integrate
    1. indoor lighting
    - Living room + dining room
    - Kitchen
    - Stairs
    - Hall/corridor
    2. zone heating
    - approx. 11 zones
    - Vaillant Ecotec Plus boiler
    3. window roller blinds
    - wired control – 16 blinds, 13 buttons
    4. open window/door alerts
    - 18 units
    5. garage door, main gate, side gate, video intercom
    6. Alarm system (e.g. Satel Integra)
    7. Mechanical ventilation system – heat recovery
    8. Air conditioning
    Many thanks in advance to everyone for all your helpful advice.
  • #242 19415503
    marcinb21
    Sterbox has one advantage – it’s Polish – but I also find it rather basic; my brother-in-law has a Sterbox at his place and I have a Lutron, so we’ve each had our own experiences.
    Remember that you’re building a home for yourself and for the long term, not just for the duration of the warranty. What matters is how long the company has been in business and what expertise it has.
  • #243 19415803
    HonestStanley
    Thanks for your reply. I’m on a tight budget, so I’m looking for the best possible solution that I might be able to expand on later.
    I take it you’re recommending Grenton?
    Does Sterbox "work well" with an alarm system, a boiler or a heat recovery system?
  • Nexo system recommended over Satel panels
    #244 19416516
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 671
    HonestStanley wrote:
    Hello everyone,
    Hello, the things you want to do cannot be integrated cheaply and effectively; if you ‘hire’ Satel control panels for this, it will never work even 50% as well as you’re currently expecting, and instead of being smart, your home will become a complete nightmare for you.
    I don’t know what your budget is, but you’ll be able to achieve a great deal – and with a very attractive finish – using the Nexo system.
  • Clarifying what cross-system integration should do
    #245 19436895
