foxx102, I considered this solution but rejected it for two main reasons.
1) At the heart of such an automation system is a single controller (in your case, the Integra). Note that if this controller fails and there is no other unit programmed in the same way, you lose control of the entire automation system.
I decided that this was unacceptable and that the only correct
system is a distributed system (if all the cables are routed to a single location, the individual controllers can be housed in one place, but I believe there should not be a single central controller)
2) Furthermore, my next requirement was that, in the event of a failure in one of the uC circuits, it should be possible to easily remove that circuit and, until it is repaired (or replaced), install a standard 230V control, such as a switch.
Another, though least important, reason why I rejected the concept of using an alarm control panel was that several alarm system installers simply advised against linking the control and security circuits of the house. They stated that the alarm system should be independent.
However, it is certainly possible to retrieve information from the control panel for home automation purposes (the Integra 64 is expandable to 64 outputs).
To sum up, I, at least, won’t be basing the entire home automation system on the alarm control panel. Perhaps I’ll use it for a few isolated and minor control functions.
WD40, I’ll have a look at those transformers for the circuit board, but I think I’ll go ahead and run an extra YDYP 2x1.5 cable anyway. It’s not that expensive, and it’ll give me more freedom when designing the circuits later on. After all, I’ll always be able to fit controllers on transformers, but I won’t be able to run that extra cable later on.
