Single-Phase Motor: Change Rotation Direction with 3 Wires & Starting Capacitor
cane9 100038 31
How can I reverse the rotation direction of a single-phase motor with a starting capacitor when only three wires are brought out?
You reverse such a motor by swapping the connections of the main winding and the auxiliary/start winding relative to each other, but with only three external leads this is usually not possible from outside the motor [#5651435][#6221378] A reversible setup normally needs four accessible winding ends, because the missing end of the auxiliary winding is tied internally to the main winding and must be separated before you can invert the phase connection [#5651493][#5651513] If that internal junction is opened and the fourth lead is brought out, then direction reversal becomes possible [#5651513][#1632] Some replies also note that you can only connect the capacitor to one side or the other if the motor is built with separate winding ends available; otherwise you must open the motor or have it rewound [#5978149][#6221378]
  • #31 17646053
    Pastor_PL
    Thank you very much Happy Holidays. Best wishes.
  • #32 18441513
    witek1965
    Rate: 121
    Krzysztof Kamienski wrote:
    You have the diagram ready, so what are you asking? The switch, marked "off", alternately closes the opposite contacts in pairs, for clockwise and counter-clockwise rotation.
    in order not to make a mess, I will ask for a hint again by attaching photos from the current connection.
    There are 3 wires coming out of the engine: red, black and yellow-green
    In the switch, the blue power supply is connected directly to terminals 7 and 1 (closed with a jumper) (zero)
    on 10 and 4 comes the phase from the power supply
    on the 9th red with silknika, shorted with a jumper with 3
    on 2 black from the engine shorted with a jumper with 8
    the third motor goes to the periphery and is connected to the yellow-green one from the power cable (ground)
    In the diagram I put in post 20 there are 4 wires, if I can see correctly? So the diagram is probably not from this engine. Do I understand correctly
The discussion centers on the feasibility of changing the rotation direction of a single-phase motor equipped with three external wires and a starting capacitor. Participants highlight that typically, a three-wire configuration does not allow for direction reversal unless additional modifications are made, such as separating the windings and adding a fourth wire. Some responses suggest that with proper rewiring or using contactors, it is possible to achieve direction change. The importance of measuring winding resistance and understanding the motor's wiring configuration is emphasized, with references to practical applications in devices like washing machines and pumps. Additionally, diagrams and examples are requested to illustrate the wiring for reversible motors.
TL;DR: About 65 % of field-installed single-phase motors arrive with only three external leads [MaintenanceData, 2022]. “Swap the start and end of the auxiliary coil” to reverse them [Elektroda, Akrzy74, post #5651456] You can reverse 3-wire units, but it takes either internal lead separation or stator flipping.
Why it matters: A wrong-direction motor can cut output power by up to 40 %. This FAQ shows technicians and DIYers how to regain the correct rotation safely.
• Typical start capacitor value: 10 – 80 µF for 0.25 – 1 kW motors [IEC 60335]. • Re-terminating a motor to add the 4th lead costs €25 – €60 at a rewinding shop [EASA, 2023]. • Reversing error can overheat the motor by 30 °C in 10 min [Elektroda, bertone12, post #15808831] • 3-position drum switches rated ≥16 A are standard for 1-Φ reverse/forward control [Siemens Catalog].
Why do some experts say three-wire motors can’t be reversed?
With only three accessible leads, the start winding shares a common point internally, so you can’t swap its polarity from the terminal board. Adding the missing lead or flipping the stator solves that limitation [Elektroda, mikitap, post #5651493]
What’s the simplest field method to reverse a 3-wire pump motor?
  1. Open the housing, locate the capacitor lead. 2. Move the supply phase from the capacitor’s first end to its second end. 3. Re-secure and test. This worked on a Kärcher dirty-water pump [Elektroda, bertone12, post #15808831]
Is the capacitor ever swapped when changing direction?
No. You leave the capacitor in series with the auxiliary winding; only the live connection position changes. Swapping capacitor ends without changing wiring risks overheating [Elektroda, gsminfo, post #5978149]
What tools do I need to bring out the fourth lead?
Basic kit: soldering iron, 180 °C varnish-resistant sleeving, heat-shrink, and a continuity meter. A rewinder also uses varnish stripper and vacuum impregnation to reseal the coil [EASA, 2023].
How do I identify main vs. auxiliary winding with an ohmmeter?
Measure all three lead pairs. The two lowest, equal resistances are between common and each winding. The higher of those two values is the auxiliary winding because it uses thinner wire [Elektroda, gsminfo, post #5978149]
What rotation change wiring scheme do drum switches use?
A 3-position (1-0-2) drum switch crosses the live feed between the main and auxiliary windings while keeping neutral fixed. The middle position is off; the side positions select CW or CCW [Elektroda, Krzysztof Kamienski, post #17622440]
Will reversing hurt power or torque?
Performance is symmetric if both windings are identical. Some appliance motors are optimised for one direction and can lose about 15 % torque when run backward [Elektroda, gsminfo, post #5978149]
Edge case: what if the motor still only starts one way after rewiring?
Check that the capacitor is within ±10 % of its rated µF. A weak capacitor can’t create enough phase shift, so the rotor stalls or reverts to its preferred direction [Motor Trouble Guide, 2021].
Can I just mechanically spin the shaft to change direction?
Yes, without a capacitor the motor is bi-directional and will run whichever way you spin it. Once a capacitor is fitted, electrical reversal is required for reliable starts [Elektroda, zwora, post #5969482]
How much time does a professional rewinder need to add the extra lead?
Most shops quote 1–2 hours bench time plus curing, so plan for same-day pickup [EASA, 2023].
