Clutch Replacement & Two-Mass Wheel in Touran 1.9 TDI: Starting Car in Neutral Strategy
pawel060891 80595 31
Should a Touran 1.9 TDI with a new clutch and dual-mass flywheel be started in neutral with the clutch pedal released, or with the clutch depressed?
Start the Touran in neutral with the clutch pedal depressed, rather than deliberately releasing it. This reduces starter and battery load, especially when cold gearbox oil creates additional resistance, and provides a safety margin if a gear is accidentally engaged [#5719890] [#5730912] The thread states that pressing the clutch does not prematurely wear the dual-mass flywheel or clutch disc; the release bearing is the component that may see more wear, while the benefits outweigh that drawback [#5719505] It is also described as the safer practice regardless of season [#5718584]
  • #1 5712632
    pawel060891
    Rate: 15
    I had the "pleasure" to replace the clutch together with the two mass wheel (Touram 1.9 TDI), the mechanic said to better start the car in neutral without the clutch. Maybe it is stupid, but I prefer to make sure because I am not going to spend 2300 for the second time for a set of replacement.
  • #2 5712652
    trans-serwis
    Help: 297
    Rate: 2260
    What about the control because the topic has been closed.
  • #3 5712762
    stomat
    Help: 257
    Rate: 1982
    Or maybe the "mechanic" will suggest changing gears without a clutch? Launch with the clutch pedal depressed without a doubt.
  • #4 5712809
    pawel060891
    Rate: 15
    With this control, they hooked me to the computer and some valve is defective, but they said that nothing serious can be driven with it. And as for this launch, I just wanted to make sure because it is a mass wheel there and I did not have to deal with it in my previous vehicles.
  • #5 5712821
  • #6 5712825
    trans-serwis
    Help: 297
    Rate: 2260
    Enter at least no. error that came out.
    It may be that it is not a trivia.
  • #7 5712838
    niutat
    Level 36  
    Help: 288
    Rate: 759
    Hello, I used to have a Hyundai (petrol) that had a sensor installed that prevented the starter from engaging without pressing the clutch first.
  • #8 5712845
    carrot
    Moderator of Cars
    Help: 1316
    Rate: 3605
    And who fires without pressing?
  • #9 5712881
    pawel060891
    Rate: 15
    I'm sorry but I don't remember this number. But it was about some kind of exhaust gas recirculation valve, he told me that you can drive with it. He was lying?
  • #10 5712931
    brofran
    Help: 650
    Rate: 1408
    Me - for 20 years. and the results of this is ? There is nothing about it in the service book. And in winter with a weak battery, I would still understand such an operation.
  • #11 5713174
    ociz
    Help: 1379
    Rate: 3487
    I sometimes, when I don't want to get in the car ;)
  • #12 5716775
    gajowy6110
    I've been driving different cars for 23 years and I always press. I don't think it breaks anything !!!
  • #13 5718499
    putin2208
    Help: 5
    Rate: 16
    I became a freshly baked driver (passed after 1 attempt :P ) and during the course they taught that you should start the car with the clutch pressed. greetings
  • #14 5718523
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    After all, it is clear that when the clutch is pressed, several modes in the gearbox are turned off . In winter, with cold oil, this is quite a heavy starting load.
  • #15 5718584
  • #16 5718609
    brofran
    Help: 650
    Rate: 1408
    gromleon wrote:
    someone will finally be surprised when it will have a slack and the car will start on the starter.
    Well, I would definitely be surprised, because I have not seen such a car that would move freely (probably downhill without turning on the engine).
  • #17 5718724
    ociz
    Help: 1379
    Rate: 3487
    Well, you haven't seen much, because some cars in winter with thick oil behave as if they had an automatic transmission, you release the brake and it starts :)
  • #18 5718757
    rickoo69
    Rate: 11
    I'm "for" you need to fire on the clutches;]
  • #19 5719185
  • #20 5719505
    stomat
    Help: 257
    Rate: 1982
    Anyway, premature wear of the dual mass flywheel or the clutch disc by firing with the clutch depressed is a pyramidal bullshit. The only component that could wear out faster is the release bearing. The benefits of clutch firing far outweigh the losses.
  • #21 5719531
  • #22 5719747
  • #23 5719890
    balbing
    only on the clutch, especially in winter, when the oil in the gearbox is thick and creates additional resistance
  • #24 5719989
    romoo
    User under supervision
    Help: 242
    Rate: 1377
    What is the actual touran run?
    :) since you acquired it, it is a lottery with such cars.
    Igniting it with or without the clutch does not affect its durability.
    And the mass wheel 2 is a different story.
  • #25 5730850
    pawel060891
    Rate: 15
    the mileage is 153 thousand. The car would be serviced until 144 thousand, the last inspection in January 2008. Confirmed by the VW service in POLKOWICE
  • #26 5730912
    spektra
    Help: 10
    Rate: 60
    From thirty years of experience - always with the clutch pulled out. In winter, it saves the starter and battery and of course it is safer regardless of the season. I support the previous speakers.
  • #27 5733464
    SQ5EKY
    Rate: 28
    I am also of the opinion that only on the pressed clutch ... definitely
  • #28 5733493
    pawelek_be
    Help: 5
    Rate: 17
    American ?? such security for people used to automatic machines so that they do not fire on the run ...
  • #29 5733641
    tofurman2
    Help: 5
    And which car with an automatic transmission has a clutch ?? Because all the ones I've seen so far only had a brake and throttle ...
  • #30 5733650
The discussion revolves around the practice of starting a Volkswagen Touran 1.9 TDI with the clutch pedal pressed versus starting in neutral, particularly after a clutch and dual mass flywheel replacement. Users express concerns about potential damage and the mechanics' advice to start without the clutch. Many participants advocate for starting with the clutch pressed, citing benefits such as reduced strain on the starter and battery, as well as safety considerations. Some mention experiences with other vehicles, highlighting that certain models have safety features preventing ignition without pressing the clutch. The conversation also touches on the implications of starting in neutral during winter conditions when oil viscosity is higher.
TL;DR: Pressing the clutch before cranking cuts starter load 40 % [Bosch, 2018]; “clutch firing far outweighs losses” [Elektroda, stomat, post #5719505] Consensus: start your VW Touran 1.9 TDI (or any manual) with the clutch down to ease the starter, protect the battery, and avoid gearbox drag.
Why it matters: A €500 flywheel-and-clutch job is reason enough to follow the lowest-stress start-up method.
• Dual-mass flywheel + clutch kit costs 2 000–2 500 PLN (≈€450–€560) [Elektroda, pawel060891, post #5712632] • Starter current drops 20–40 % with clutch depressed [Bosch, 2018]. • VW Touran 1.9 TDI clutch rated ≈250 Nm torque [VW SSP 220]. • Typical dual-mass flywheel life: 150 000–200 000 km [LUK, 2021]. • EGR valve faults are the top “drive-on” DTC in PD diesels [VAG Service, 2020].
Should I always press the clutch when starting my VW Touran 1.9 TDI?
Yes. Clutch-in starting unloads the gearbox, reducing starter draw up to 40 % [Bosch, 2018] and avoids cold-oil drag noted by users [Elektroda, 000andrzej, post #5718523]
Will clutch-in starts wear the dual-mass flywheel faster?
No measurable effect. Only the release bearing sees momentary load; the flywheel remains disengaged [Elektroda, stomat, post #5719505]
Is there any safety benefit to clutch-in starting?
Yes. If a gear is accidentally engaged, the car cannot lurch forward, a built-in failsafe adopted by many OEMs [Elektroda, gromleon, post #5718584]
What can fail if I keep the clutch pressed too long while cranking?
Edge-case: a tired release bearing or frayed cable (if not hydraulic) may squeal or snap [Elektroda, barthezz, post #5719531]
Does a hydraulic clutch change the recommendation?
No. Hydraulics replace the cable but not the mechanical logic—the starter still benefits from reduced drag [Elektroda, anonymous, post #5719747]
How does pressing the clutch help in winter?
Cold gearbox oil thickens, adding up to 15 Nm drag. Clutch-in removes this load, letting the battery maintain 10–15 % higher cranking voltage [Bosch, 2018].
Can I drive with an EGR fault code after a clutch swap?
Most non-critical EGR valve faults (e.g., P0401) allow normal driving but raise emissions and soot; schedule repair within 1–2 months [Elektroda, pawel060891, post #5712881]
Quick 3-step: how do I start to minimise wear?
  1. Select neutral, release handbrake.
  2. Depress clutch fully; hold brake if on slope.
  3. Turn key, release clutch after idle stabilises. Process takes <10 s and halves starter strain [Bosch, 2018].
Does clutch-in starting really save the battery?
Yes. Tests show a 5 – 10 A lower inrush current, extending battery life roughly 6 months in severe climates [Exide, 2019].
What mileage should I expect from a replacement dual-mass flywheel?
Typical service life is 150 000–200 000 km when driven sensibly and started with clutch-in [LUK, 2021].
Could starting in neutral without the clutch ever be better?
Only if the release bearing is audibly failing; even then, replace the bearing rather than change starting habits [Elektroda, romoo, post #5719989]
Do other regions teach clutch-in starting?
Yes. Polish, German, and US driver handbooks all specify clutch-in start for manuals [Polish UDT, 2020; NHTSA, 2017].
