Free Energy: Exploring and Discussing the Searl Generator's Magnets, Rings & Rollers
haker201200 139216 175
How can I start a Searl generator built from magnets, rings, and rollers, and does this design make sense?
You cannot meaningfully start it from the information shown, because the thread repeatedly concludes that there is no working description of the generator’s construction or operation, and that the whole “free energy” claim is unsupported [#10116297] [#13001264] [#14539401] [#14575792] If you want to build anything real, you need exact materials, dimensions, magnetization details, and a valid power/drive method; otherwise you are only copying the external appearance and will not get a working device [#13001264] [#13017306] One technically grounded comment says the device would need an electrical mechanism, since a changing magnetic setup alone is not enough, and any induced EMF obeys Lenz’s law, meaning the motion is opposed rather than self-sustaining [#14575792] [#16601676] [#16738267] Several replies also point out that claims about special magnetic tracks, alternating-field magnetization, or self-running operation are physically confused or impossible as stated [#11494137] [#11517765] [#11518619] So the best practical answer from the thread is: treat the shown ring-and-roller layout as a non-working mockup unless someone can provide a complete, experimentally verified drive scheme and reproducible measurements [#13015445] [#14539401] [#13002294]
  • #61 12997291
    e8500
    Rate: 29
    I made a program where I take the mysterious number 12 and avg. outside the ring. The program calculates the dimensions of the roll, dia. ext. ring and height.
    e8500 wrote:
    I checked carefully and the program works fine. i made it in excel now i make it as *. exe file
  • #62 13000858
    e8500
    Rate: 29
    It is a program that calculates the dimensions of the rings needed to build the generator.
  • #63 13001182
  • #64 13001264
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    Because this business is about someone paying and not knowing why. Nothing will be "free", but to try and do, you will have to pay for information that will prove to be worthless. How many rings will fit, I can count and without this program, but with or without the program, I will not get free energy from it. If someone really wanted to show that such a generator works, he would write how he did (with details: materials, dimensions) and what he got. Instead there is (not only here) a lengthy discussion of how to calculate the number and dimensions of reels - for a distraction from the fact that there is really nothing meaningful to show here. And I have the impression that the e8500 has just shown that this system, which it supposedly fell apart, was not there at all.
  • #65 13001558
    saskia
    Help: 174
    Rate: 1086
    This is exactly the same as with bills for: electricity, gas, telephones, internet, and especially for CO2 emissions, etc. :-)
  • #66 13001670
    e8500
    Rate: 29
    you have a free download no points i don't care about them :)
    I live in a country where the neighbor is not interested in what I do in the garage so I have St. peace and it is not Poland.
    Moderated By ANUBIS:
    3.1.13. It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible.
  • #67 13002294
    _jta_
    Help: 3212
    Rate: 4258
    :arrow: e8500 - Did the forum people come to ask you to introduce Searl's generator? You started writing about it yourself, you try to convince others to do it, so I demand that you do it honestly. If you were just doing it in your garage it would be your private business and probably no one would ask, not me anyway.
    :arrow: saskia - Electricity, gas, telephones, internet are some tangible benefits for the recipient that require some work of the supplier (or his contractors). You can have information about where they come from and how they work for free, as long as you do not go into details, e.g. how to have a generator efficiency of 99%, not only 80%.
  • #68 13002402
    e8500
    Rate: 29
    I do what I do I made a program for my own needs. I posted it here because I know there are people who want to do it or are just starting, so I will share what I did in 10 minutes. this is version 1.0 I want to do a program on 3 rings.
  • #69 13003211
    _jta_
    Help: 3212
    Rate: 4258
    And who needs to calculate the dimensions of the elements of the device, about which you do not know how to work and how to make them work? It is a sick approach: you do not know why and how to fold, but the dimensions are calculated - with the result that you may not notice the lack of knowledge about what is important, because having dimensions you can do something, although it is only an apparent action.
  • #70 13003401
    e8500
    Rate: 29
    I can see the criticism here. I did not finish physics to read such posts. why was someone assuming this topic? probably to find out something, right? unlikely to write in this forum anymore. Foreign forums are more meaningful on various topics, especially Russian and US forums. you can find out more about the generator outside of Poland what you saw about Polish google searl is 1 out of 100 pieces of information. how can someone not afford to order a magnet with sr. 300mm and larger should not be involved on this subject because he does not know what it is about. good luck in construction.
    3.3. The user is obliged to immediately follow the moderator's instructions.
  • #71 13003522
    _jta_
    Help: 3212
    Rate: 4258
    Yes? And you wrote yourself I found a company in Poland, the largest magnet they can make for 200mm and that's what I order ( # 56 25 Nov 2013 17:29 ) - hence (in conjunction with what you just wrote) the conclusion that you do not know what is being said and you should not contribute. ;)
  • #72 13003782
    e8500
    Rate: 29
    because there are few companies that magnetize with alternating and direct current at the same time.
  • #73 13003942
    _jta_
    Help: 3212
    Rate: 4258
    And what does this have to do with the fact that you (apparently) order a 200mm magnet yourself, and you require others who would like to comment to order a much larger one? By the way, if there was a point, I could order one, but what for? It would cost something around my monthly salary, definitely too expensive to play - I prefer to buy something cheaper, and at the same time useful and safer.
  • #74 13004081
    e8500
    Rate: 29
    magnetization with different currents and frequencies is of great importance because the field strength and the shape of the curvature of the magnetic wave change. searl is a cheap construction i used to play with jet engines for radio controlled airplanes. such a motor costs even 4,700 euros, so when I spend 2000 euros on magnets, nothing will happen except that the searl will be resurrected.
  • #75 13004456
    JohnRing
    Rate: 13
    I think that Searl was inspired by the planetary system when designing his magnets. And in it the basis is, among other things, Kepler's laws. This would be related to the non-linearity of the rotational speed of the rotating rollers and, at the same time, to magnetize them not along the axis, but at the right angle.
    I will give my colleague a link to the film in which, I think, a man used the nonlinearity of the rotational speed of two magnets at the input of the system.
    http://www.youtube.com/watch?v=vBRDvwrFwVo
  • #76 13004469
    _jta_
    Help: 3212
    Rate: 4258
    If you want, spend it on yourself, but don't persuade others to do it. Your idea to try to do this, so let it be done at your expense. Oh, and it would be dishonest of me if I hadn't warned that the "Searl's generator" would not work because it was a scam (some Searl fan sent me material, checked and know) - so be warned. You still haven't explained why you want others to do something with a larger magnet that costs over 3 times more than the one you are supposed to use yourself.
  • #77 13004622
    e8500
    Rate: 29
    I know that. the angle is the same as the slope of the earth. the rollers are magnetized along their axis but the ring at an angle.
  • #78 13005109
    jamtex
    Help: 12
    Rate: 247
    Most things, and maybe everything we do in our lives, we do for a purpose.
    Maybe colleagues who build Searl's generator tell us about this goal? What do they want to prove, achieve and what is this generator for them?
    If someone starts construction, he should know the principle of operation, so what is it like?
    Otherwise, a sterile discussion will continue for 5 years.
    I don't want to be malicious, but in a moment it turns out that:
    - wrong size of the magnets,
    - bad magnetization,
    - bad currents during magnetization,
    - wrong angle,
    - another.
  • #79 13005485
    Radd
    Rate: 8
    For several reasons, and everyone knows it:
    - for science - acquiring knowledge (science develops through experimentation);
    - for satisfaction if something new is discovered;
    - probably everyone has dreamed of flying and moving freely since childhood - it is still inside a person;
    - some even for fame;
    - and probably everyone would like to have their own power source and not worry about bills;
    People will always look for new solutions this is our nature, and when thousands or millions are looking, someone is more likely to discover something new. There is probably a reason why the saying is that if something can't be done, take someone who doesn't know about it - he'll come and do it.
  • #80 13006098
    _jta_
    Help: 3212
    Rate: 4258
    It will not advance science, unless those who do learn the working methods that science has worked out - but who will want to apply them? From their point of view, as expressed in the reasons given, they have a serious inconvenience: they resist following illusions - which was precisely the reason why science accepted them; and the second, also serious for them: you have to put a lot of effort into learning them.
  • #81 13006607
    Qardius
    Rate: 38
    I entered on Google and such magic appeared to me Link I found on other sites also something about flying it. Sci-fi movies more realistic watched.
    Nobody has received a Nobel prize from free energy yet. We are still waiting.
  • #82 13006971
    saskia
    Help: 174
    Rate: 1086
    I think that if every second utter is warnings against frauds and device failure, you could easily leave the topic to those who are interested in it and not interfere again with warnings etc. information.
    Those who want to try something will do it regardless of pessimistic and warning information.
    So, maybe enough to make a fuss about this topic.
    Allow interested parties to exchange information and experiences.
  • #83 13007184
    _jta_
    Help: 3212
    Rate: 4258
    I suppose I have a lot more information from the web than they do, I just don't know how to share it.
  • #84 13007694
    saskia
    Help: 174
    Rate: 1086
    Best, fast. :-)
    But you can gradually and systematically so that you can work them out without jumping from fast to fast. :-)
  • #86 13008603
    _jta_
    Help: 3212
    Rate: 4258
    saskia - First of all, there is a technical problem, because there is a lot of it. Secondly, I don't know if it's legal - you would have to review it all and see if I infringe someone else's copyright. Thirdly, I work in a reputable institution and it is not proper for me to publicize nonsense. There are probably ways to do all of this, but you'd have to find them.
  • #87 13009210
    e8500
    Rate: 29
    the way to upload files to the server is simple. you create an account on chomikuj and upload at the end you give a link as if you found it on the net and who will know that you gave these files
  • #88 13009230
    _jta_
    Help: 3212
    Rate: 4258
    And you think that when a copyright holder discovers the materials to which he has rights to hoard them, they will not inform him who uploaded them? Anyway, it's not right for me to pretend that I wasn't.
  • #89 13009315
    e8500
    Rate: 29
    they won't tell him who uploaded them. in a minute someone detects that these files are on the servers, it will take some time and until then you can easily download them
    Added after 4 [minutes]:
    there is another way to upload files to the server. files can be uploaded to your own server and made available then it is much more difficult to locate the file because coryright protected files are usually searched for company servers, not private ones
    additional protection of files is packing them in rar with asci code type password
    The moderator can pay attention and the user ignores it, and there is only one reaction to such behavior.
  • #90 13009786
    saskia
    Help: 174
    Rate: 1086
    Or create an account on a Chinese portal and there, and then load it from there. :-)
The discussion revolves around the Searl Effect Generator (SEG), a device purported to generate free energy using magnets, rings, and rollers. Participants express skepticism about its feasibility, citing a lack of credible information on its construction and operation. Some contributors mention the need for specific materials and designs, such as the use of neodymium magnets and the importance of magnetic fields. Others argue that the device is a scam, pointing out that no successful prototypes have been demonstrated despite decades of claims. The conversation also touches on the principles of magnetism, energy generation, and the challenges of creating a working model. A few participants suggest theoretical approaches to powering the generator, while others emphasize the necessity of scientific knowledge and practical experience in building such devices.
TL;DR: Average Polish electricity demand runs at 700 W per capita [Elektroda, jta, post #15269541]; “nullius in verba” reminds us to test, not trust [Elektroda, jta, post #13019057] No verified Searl Effect Generator (SEG) out-produces input power. Why it matters: Builders risk money, safety and time chasing an unproven machine.
• Mean grid losses: 7-8 % during transmission [Elektroda, wnoto, post #15281961] • PV panel yield: ≈ 25 W per m² average in Poland [Elektroda, jta, post #15268632] • Custom NdFeB ring ≤ Ø200 mm quoted at ~€2 000 [Elektroda, e8500, post #12991631] • Reported vertical wind rotor (Ø3 m) delivered ~50 W [Elektroda, RADASSS, post #15270930] • SEG prototypes use 12 rollers per ring in the common design lore [Elektroda, e8500, post #12991631]
1. Does a working Searl Effect Generator exist?
No independent lab or peer-reviewed study has replicated continuous excess energy from an SEG. Supporters supply photos and videos, but analyses revealed edits or fakery [Elektroda, jta, post #11518356]
2. What parts make up a typical SEG?
Most builds show three concentric magnetic rings (stators) and sets of magnetised rollers that orbit each ring. Materials advertised include ferrite or NdFeB magnets, copper, aluminium, and sometimes Teflon separators [Elektroda, e8500, post #12991631]
3. Why is the magnetisation pattern considered critical?
Builders claim each stator/roller must hold alternating and DC ‘paths’ to guide rollers. Critics note only DC permanently magnetises; adding AC merely demagnetises portions, yielding no special track [Elektroda, Artur k., post #11515259]
4. Can alternating plus direct current really magnetise stators?
No. Adding an AC component cancels sections of the field; permanent magnetisation requires steady DC, confirmed by magnetic hysteresis data [Elektroda, Artur k., post #11515259]
5. How much power could an SEG deliver if it worked?
Claims range from 3 kW tabletop units to megawatt craft, yet no measured output beyond losses has been published. A builders’ forum target of 500 W is still unverified [Elektroda, RADASSS, post #15267000]
6. What failure or hazard reports exist?
One test ring accelerated, left its track and punctured a computer monitor, illustrating projectile risk [Elektroda, e8500, post #12991631]
7. What do custom magnets cost?
Polish quotes for Ø200 mm composite rings approached €2 000 excluding tooling [Elektroda, e8500, post #12991631] Larger diameters escalate quickly, so full three-ring sets often exceed €10 000 total.
8. Isn’t the SEG just another electric motor?
Yes, according to classical physics. Any EMF generated induces counter-torque per Lenz’s law, so input always equals output plus losses [Elektroda, jta, post #16601676]
9. How did Wikipedia treat Searl articles?
Both ‘John Searl’ and ‘Searl Effect Generator’ pages were deleted for lack of verifiable evidence [Elektroda, jta, post #11516859]
10. Why do fraud allegations appear?
John Searl collected money for decades while never reproducing his claimed 1940s result; even his own company still seeks a ‘Eureka’ build [Elektroda, jankolo, post #11518475]
11. What statistic shows renewable context?
Poland’s 25 GW peak demand divided by population equals 700 W per person [Elektroda, jta, post #15269541], highlighting the scale any alternative source must meet.
12. How large must a solar array be to offset one person’s average use?
At 25 W/m² mean yield, covering about 28 m² per person supplies 700 W [Elektroda, jta, post #15268632]
13. How-to: size a household PV backup (3 steps)
  1. Multiply daily kWh need by 1.4 to cover inverter and battery losses. 2. Divide by local sun-hours to get panel kW. 3. Multiply by 40 m² per kW to estimate roof area.
14. What’s the verdict on alternating-current ‘tracks’?
“You can only magnetise permanently with direct current” [Elektroda, Artur k., post #11515259]; alternating fields add nothing but heat.
16. Could imploding air bubbles drive rollers?
Cavitation provides thrust in liquids; in air, energy density is tiny. No experiment shows measurable roller torque from gas implosion [Elektroda, jta, post #15263467]
