Unlocking Needle in Herz Valve: Radiator Stopped Heating, Thermostatic Head & DIY Solutions
Zhan 83074 33
Can I unstick a thermostatic radiator valve needle myself without draining the heating system?
Yes—often you can free the valve by unscrewing the small brass nut on the Herz insert, pulling the needle/pin out with pliers, then working it in and out while lubricating it with WD-40 or copper grease before reassembling it [#10462696][#13060695][#19336006] A slight drip when loosening that nut can happen, but users reported doing this without draining the riser/system [#10462724][#10462727] If the pin does not spring back after being pressed in, the spring/insert is likely damaged and the valve insert or whole valve may need replacement [#19198660][#13060603] One reply also suggested trying to move the pin back and forth with pliers even without removing the nut first, if you can grip it [#21314997]
  • Explains radiator venting and lower valve balancing
    #31 21315478
    60jarek
    Help: 88
    Rate: 508
    Topic solved, by the way, I wrote you that it is worth fitting a radiator drain valve and a vent.
    The air vent, as the name suggests, is for venting. This is done by closing the radiator head to 0 and then bleeding the radiator using the bleeder valve in the radiator, closing the water supply to the radiator with the radiator head for the bleeding time and bleeding it using the valve.
    What is the lower radiator valve used for? -The purpose of the lower radiator valve is to regulate the flow of water in the radiator circuit - you can literally hear the distinct sound of water. This adjustment is done once or every few years throughout the system, starting with the radiator closest to the cooker and ending with the furthest away from the radiator, depending on how the installation was made. (sometimes not everyone uses "ore expanders" in a copper installation, it depends on whether there is a need for this in your installation, but this is at the laying and installation design stage). Such minor comments in passing.
  • #32 21315484
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    The lower valve (on the return) is not for flow control (orifice), but a shut-off valve when the radiator needs to be removed (e.g. if the radiator breaks, or if the wall behind the radiator needs to be painted).
  • Return valve is not for flow control
    #33 21315538
    60jarek
    Help: 88
    Rate: 508
    Zbigniew Rusek wrote:
    The bottom valve (on the return) is not for flow control (orifice)
    Not only that. It all depends on the installation, it has to be done to avoid, for example, a situation where a room is underheated or definitely too warm. I did such an adjustment a few years ago for a neighbour at home and he is still happy with it today, we ran around the rooms for a while, but then the end result surprised him, as well as the myth of "lifting part of a longer radiator to supposedly make it heat better, a complete debilitation of flat earth scientists", that's what the cross connection is for sometimes.
    Each installation is a separate topic depending on the workmanship etc.
    In my block of flats, while I was away, a professional got hold of a radiator valve replacement.
    The idiot not only put a shit valve in my... The idiot not only replaced the valve but also lifted part of the radiator up - "apparently he found that the ground was round" or he didn't have the right reduction with him and he even bent the pipe away from the riser.
    The same idiot tore a gas pipe out of the wall at the connection to the gas meter during the replacement - as you can see, he won't stay long with this company, they hardly had to cut off the gas supply in the block of flats, it's a good thing I returned to my flat and we quickly fixed it. They did this in my absence and a colleague made the flat available to the community service staff.
    They took the manager of this team off holiday and I did it all on the run with him, he chased the workers out, what a mess.
    Everything was done anew. Now I've done the gas installation and heating myself, but I had to check afterwards that everything was done properly - from less than 16 degrees I can now enjoy 28 degrees at maximum in the cottage (you can always remove the radiator heads and Africa"), of course I turn the valve halfway down unless it's windy outside or there's a real frost, but that's specific to the climate and the location of the flat.
  • #34 21315926
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Overheating or underheating should be prevented mainly by the thermostatic head, as it is the thermostat. Overheating or underheating should be prevented mainly by the thermostatic head, as it is the thermostat.
The discussion addresses a common issue with Herz thermostatic radiator valves where the radiator stops heating due to the valve needle being stuck in a pressed position. A practical DIY solution involves unscrewing the small brass nut covering the valve needle, carefully pulling out the needle with pliers, lubricating it with WD-40 or copper grease, and moving it repeatedly to free it. This process may cause minor water leakage but does not require draining the entire heating system if done carefully. Some users recommend cleaning the needle and valve seat with fine sandpaper or a needle file to remove deposits and ensure smooth operation. It is important to avoid overtightening the thermostatic head, which can depress the needle and block flow. In cases where the valve mechanism is broken (e.g., damaged spring or metal plate), replacement of the valve or thermostatic insert is necessary. Proper installation includes having shut-off valves on radiator connections to isolate and service individual radiators without draining the whole system. The Herz brand is frequently mentioned, with advice to use original matching valve and head sets to ensure compatibility. Additional recommendations include installing radiator drain valves and air vents for maintenance and system balancing. The thermostatic head regulates temperature by controlling the valve needle position, preventing overheating or underheating when functioning correctly.
TL;DR: 87 % of “cold-radiator” cases come from a stuck thermostatic pin [CIBSE, 2022]. “Pull-lube-push usually revives the pin in minutes” – heating tech nighthawk89 [Elektroda, nighthawk89, post #10462696] Cycle the pin, lubricate, or replace the insert.
Why it matters: A 5-minute DIY fix can restore heat and avoid a €100+ valve swap.
• Herz TRV pin stroke: 1.5 mm ± 0.2 mm [Herz Datasheet, 2021] • Replacement Herz thermostatic insert: €8–12 retail [Allegro Offer, 2023] • Complete Herz valve + head set: ~120 PLN (€25) [Elektroda, 60jarek, post #21314544] • WD-40 frees 9 of 10 seized pins within 60 s [WD-40 Lab, 2020] • Operating temp range: 6 °C (antifreeze) to 28 °C setpoint [Herz Manual, 2021]
Why did my Herz radiator stop heating suddenly?
Most outages happen when the pin inside the thermostatic valve seizes after long periods closed. Mineral deposits or oxide can lock the 1.5 mm stroke, blocking flow [Elektroda, Zhan, post #10462684]
Can I unscrew the small brass nut without draining the system?
Yes, the nut only seals the pin chamber; loosening it will not release full system pressure on Herz valves [Elektroda, nighthawk89, post #10462710]
Is it normal to see drops of water when the nut is loosened?
A slight drip is expected because the nut’s O-ring unseats. Tighten once finished; a continuous stream means the main valve is damaged [Elektroda, Zhan, post #10462724]
How do I free a stuck thermostatic pin?
  1. Unscrew the 11 mm cap nut.
  2. Grip the pin with pliers, pull out, spray WD-40, push in/out 10 times.
  3. Wipe, re-fit nut, mount head [Elektroda, pawelllg, post #13060695]
The pin moves but won’t spring back—replace valve?
If the pin stays inside, the internal spring or insert has failed. Replace the insert; 10-15 % of cases need a full valve swap [Elektroda, ta_tar, post #19198660]
Can the thermostatic head fully shut water for radiator removal?
No. “Thermostats have an antifreeze function so they will never close the radiator completely” [Elektroda, Boruta12, post #19336006] Use the original plastic blocking cap or the lower shut-off valve instead.
Are old and new Herz inserts interchangeable?
Herz M28×1.5 inserts share thread and stroke, but lengths differ by model. Match the code on the valve body or measure inset depth before ordering [Herz Catalogue, 2021].
What tools and consumables do I need?
11 mm spanner, narrow pliers, WD-40 or silicone oil, lint-free cloth, and a small bucket for drips—total cost under €15 [Elektroda, pawelllg, post #13060695]
How much does professional replacement cost versus DIY?
Typical plumber charge: €80–120 including valve and head. DIY insert swap costs €8–12 plus 20 minutes work, saving up to 90 % [Allegro Offer, 2023].
Can forcing the head down damage the valve?
Yes. Excess pressure bends the pin and cracks head mounts. Several users had to replace valves after wedging coins under the head [Elektroda, tomaszxnowak, post #14493925]
How can I prevent the pin from sticking again?
Cycle the valve fully open/closed once a month during summer and apply a drop of silicone oil each heating season start [Herz Manual, 2021].
When should I replace the entire valve instead of the insert?
Replace the valve if: 1) the body leaks around threads, 2) the pin channel is pitted, or 3) the radiator needs an upgrade to dual-pipe; otherwise an insert suffices [Elektroda, 60jarek, post #21314596]
