cooker with Recalart Economic 3000 controller - alarm transmission via control panel
greg161 5181 5
  • #1 11729963
    greg161
    i have the above-mentioned controller in my cooker and I would like to connect it to the control panel in order to receive information that the alarm on the cooker has been activated, I have not found any interface in the controller but there is a red diode which starts to light in an alarm situation, so the question is how to connect it to the control panel (Satel Integra)?
  • #2 11749761
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    What voltage is applied to this diode?
  • #3 11784479
    greg161
    From what I measured while this diode was on, it was 1.7 V
  • #4 11784564
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    A little low, look for where there is any higher voltage from 5 volts upwards in the driver when the diode is lit.
  • #5 12001134
    greg161
    It took me some time (I had to educate myself "a bit" in electronics) but in the end I think I found a solution, for now it's a test, but it works, it remains to try it on the cooker (which I intend to do soon)
    i've duplicated the signal by connecting an optocoupler in parallel to the alarm diode, which controls a second independent circuit, from which I read the signal on the Arduino, and this via serial to the computer, where a Python script runs, which waits for information about the alarm (lighting of the diode on the cooker) and sends me an sms in case of failure
    now i've had another look at the first post, of course the same can be hooked up to the mentioned control panel instead of the arduino
  • #6 12451764
    bull59
    Rate: 9
    Has anyone connected the Integre to a Recalart Economic 3000 controller?
    Greg161 and how does it work?
