Maximum number of buttons per light switch without smart home
nicholasp 3231 5
  • #1 11758327
    nicholasp
    Welcome
    i have this question from the light switch series.
    How many buttons can there be in one box?
    I'd like to add that I don't have a smart home, and I wouldn't want to make an unknown number of boxes one under the other.
    Would it be possible to do 3/4 buttons in one or is the standard 2 the maximum?
    I found a series like this:
    http://www.berker.com/pl/polska/produkty/serie-produktow/q1/przelacznik-4-krotny/
    If anyone has other ideas (GIRA, BERKER, etc) then please help.
    Brand or model does not count.
    Greetings
    Nicholas
  • #2 11758349
    bartekfigura
    Level 30  
    Help: 112
    Rate: 522
    It's hard to get switches with more than 2 switches, but Ospel makes 3-fold switches, so 4-fold switches are rather hard to get
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    This Berker Q.1 is exactly what you don't want (EiB). And as far as Gira is concerned, max triple. E.g. Link
  • #4 11759026
    stkop
    Help: 14
    With the Tem [http://tem.com.pl] and Vimar fittings you can even connect more than 5-6 230V switches.... but a special box is required.
  • #5 11759042
    nicholasp
    andrefff wrote:
    This Berker Q.1 is exactly what you don't want (EiB). And as far as Gira is concerned it's a triple max. E.g. Link
    Thanks, that's exactly what I meant. Is there a problem there if I connect one of the buttons by staircase?
  • #6 11759071
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    You won't connect in a staircase, what's more the switch doesn't have feet, so the boxes have to be with screws.
