How do I configure the RS485 ports on the A1500 Elster meter and Moxa converter?
betonn 5289 2
  • #1 12157521
    betonn
    Help: 10
    Rate: 10
    Welcome
    Here is the issue to be solved.
    An A1500 Elster energy meter with two RS485 ports (the first one occupied by a modem), a Moxa nPort 5130 RS485/Lan converter, AlphSET software.
    I connected such a meter to the RS485 converter. In the AlphaSET counter software, I set up communication with the counter via TCP/IP. There I inserted the IP parameters of the converter. This works.
    AlphaSET sees and connects to the converter, but the converter does not communicate with the counter.
    What potru parameters do I have to zapoid to be communication counter <=> converter<=> AlphaSET?
  • #2 12160505
    duddy
    Help: 56
    Rate: 186
    You should have these parameters with your device because it was the manufacturer who set the speed and other communication values with the software.
    PITSTOP
    Piłkarska 21, Gorzów Wielkopolski, 66-400
  • #3 15890701
    Bazic
    Help: 7
    Rate: 40
    An old topic admittedly, but I have recently seen such communication set to 300.7.e.1 - I would check this first.
    And does anyone know where to get this AlphaSet program from?
