Raspberry Pi – home surveillance with USB or IP cameras, what to choose?
MES Mariusz 36156 10
How can I build a Raspberry Pi home surveillance system with USB or IP cameras that supports web viewing, snapshots, video recording, motion detection, and recording on motion?
Use the Motion software stack: it provides video stream customisation, motion detection, recording, video proxying, and can work with any Video4Linux device such as USB cameras as well as external JPEG streams from IP cameras [#12505923] For web viewing, combine it with MotionBrowser and Cambozola to view JPEG streams in a browser, including older IE setups [#12505923] A Raspberry Pi project page is also pointed to as a practical example of a Raspberry Pi webcam server using Motion [#12246936] In one report, Motion was said to work well on a Raspberry Pi with a single USB camera, and support for several cameras at once was described as possible but not yet fully tested [#12537745] ZoneMinder was mentioned as a complete open-source DVR alternative, but it was considered harder to compile and maintain than Motion [#12505923]
  • #1 12167254
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 223
    Does anyone know of any projects using the Raspberry Pi as a home monitoring system ?
    I am interested in:
    - the use of cheap USB cameras or IP cameras,
    - web panel for viewing cameras
    - taking photos
    - video recording
    - motion detection on the basis of video changes
    - recording of video upon detection of movement
    - taking a photo upon detection of movement.
    Thanks in advance for any links, leads you find.
    Regards
    Mariusz
  • #2 12246936
    filokolo1
    Rate: 14
    Have your colleague look for Raspberry Pi compatible cameras. As for the Raspberry pi model, I recommend B because it has an internet connection, and the software is the best thing to look for something on the internet (a program that creates a simple page on the Raspberry Pi that has a live image from the camera or refreshed every 1sec)
    Link: http://pingbin.com/2012/12/Raspberry-pi-web-cam-server-motion/
    This is a general explanation of what and how to do with this camera.
  • #3 12477108
    blur
    Help: 12
    Rate: 58
    Does it have to be on a Raspberry? Is this computing power enough for a few cameras? Is this to be a thesis or a device for continuous operation? If the latter, I would consider a dedicated recorder.
  • #4 12477783
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 223
    Will a dedicated DVR instantly send you photos to gmail or hangout and Picasa when motion is detected? Is it cheaper? Or more energy efficient? ;-) Raspberry can easily handle several cameras with motion applications :-) And you can expand the functionality as you like. I used to use a dedicated device with a predetermined and very limited functionality. I would not make that mistake again ;-)
  • #5 12477852
    blur
    Help: 12
    Rate: 58
    I was more concerned with video recording, what resolution would it be and how many fps ? from several cameras simultaneously.
  • #6 12478189
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 223
    I have not done this type of testing. Photographs of a moving object are sufficient for me. I don't save video to disk, at most a few - a few dozen frames (jpeg 640x480) when motion is detected.
  • #7 12479236
    blur
    Help: 12
    Rate: 58
    maybe foscam cameras and send to some server ?
  • #9 12490218
    blur
    Help: 12
    Rate: 58
    But he insisted on this crap, are you counting on someone to give you a ready-made ?
    Szymon Tarnowski
    Help: 61
    Rate: 181
    blur wrote:
    But he insisted on this crap, are you hoping someone will give you a ready-made one ?
    And why not? Complete open source DVR system http://www.zoneminder.com/ I don't know if the raspberry will pull this off. I used to try to compile it from source but it's a massacre, each version is only compatible with a specific video codec version. Plus/minus 1 minor codec version number causes compilation errors. I gave up on compiling and use something simpler http://motion.sourceforge.net/ In combination with MotionBrowser and Cambozola (to watch JPEG streams under IE, as FF has built-in support) it has worked perfectly for me for over a year. At my place it works with a 4xBT878 DVR card, previously it worked with a 1xBT878 TV card, I assume any Video4Linux device (even USB) will work. Additionally, the software embraces external JPEG streams from IP cameras. There are quite a lot of possibilities for video stream customisation, motion detection, recording, video proxy. I recently hooked up the free programme "IP Camera Viewer" under WP7 and I can view on my phone.
  • #11 12537745
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 223
    Motion works great for me too, and on a Raspberry ( RaSp485berry project ). For the time being on a single USB camera, but if anyone would like to contribute to the development of the project (support for several cameras at the same time - it's possible, but I haven't had time to play - test, please contact me :-)
