warmet, dedietrch - Boiler house - control of two boilers and four co-generation pumps
dar 3003 1
  • #1 12380953
    dar
    Rate: 31
    I am in the process of commissioning a boiler room in a detached house: the boiler room has a Kostrzewa Warmet Ceramik 18.5 kW furnace + a De Dietrich MCR3 single-function gas boiler. The whole works in a closed system. I have four circulation pumps in the system: floor up, floor down, radiators (ladder ones in the bathrooms and a regular one in the garage) and DHW. The Kostrzewa cooker has a Luxus 4 controller - it can control two circuits + DHW.
    In addition, I am planning to add solar panels to heat DHW. The DHW tank is designed for this.
    The assumption is that the gas boiler will be the main source of central heating (if finances allow), and the solid fuel boiler - an additional element during the transition periods from spring to autumn.
    I did some research on the web and found controllers and pump controllers from, for example, AURATON and EUROSTER.
    Perhaps someone has come across a neat control that masters all the elements? ;-)
  • #2 13487246
    dar
    Rate: 31
    It has been a while and it is appropriate to mention the progress.... The subject has been successfully connected as follows for the time being... The hot water is controlled either by a circulating pump or by a three-way valve on the gas cooker. The upstairs and downstairs underfloor pumps are controlled by the expansion module from the gas cooker - setting the temperature results in a request to the gas cooker. If the gas furnace is switched off, the pumps are activated when the fescue heater is switched on. The remaining issue is the control of the radiator circuit - I bought a simple water temperature controller. And it works:-)
    D
