Max Performance & Speed of Twisted Pair Cable: Identifying Crossover vs Straight & Usage Scenarios
okular766 51297 43
Can a twisted-pair cable reduce transfer speed, what is the maximum speed over twisted pair, how do I recognize a crossover cable, and what happens if I use crossover vs straight-through between devices like router-router or PC-router?
A twisted-pair Ethernet cable does not normally reduce speed by itself; the link speed is mainly determined by the cable category and the equipment, with Cat5e supporting 1 Gbit/s and Cat6/Cat6a up to 10 Gbit/s, and a standard Ethernet segment limited to about 100 m [#12768952][#12768982][#12771517] A crossover cable is identified by swapping the orange and green pairs between the two ends, while the blue and brown pairs stay in the same positions [#12772293] On modern devices with auto MDI/X, crossover vs straight-through usually does not matter [#12768952] On older equipment, the cable type mattered: crossover was used for direct device-to-device links, while straight-through was used for PC-to-switch/router style connections [#19095677][#12774215] If the wrong type is used on older gear, the link may simply not come up or negotiate properly [#12768952]
  • #31 12776957
    Herbatniczek
    Rate: 8
    Satellite just doesn't work if you don't have a second link to send .... you can possibly have a satellite transmitter but that's completely different costs.
    ALWAYS HAVE TO BE DIFFERENT SIDES ... you like it or not, but you won't change the physics: p
  • #32 12777560
    DVDM14
    Help: 315
    Rate: 553
    It used to be like that, modern satellite Internet systems are capable of transmitting signals to satellites. That is why they usually use their own antenna and a special converter adapted for this purpose.
    While this solution is indeed still in use, the costs. :D
    No less that there is an internet connection the transmission must absolutely be bidirectional. How do you envision one-way communication? You can receive the data, but how, when you can't send any, tell the server that it has to send anything at all? To load a page, first you send a request to DNS, then you receive the IP of the web server, you send a query to it, it responds with the downloaded data. Not to mention the numerous data sent at the level of the TCP protocol (establishing a connection, acknowledgment of packet receipt, etc.). I will not lecture on communicators that somehow send a message, e-mail and other, absurdly obvious examples. :P
  • #33 12778707
    okular766
    Pupil
    Rate: 17
    Well, gentlemen, how does VoD work on SAT TV because it is 1-way reception, how does the supplier know what movie I have chosen and will someone explain it to me? Because the SAT TV works in one direction, right? Or searching for SAT channels, how does the satellite know I'm going to scan the channels and send them to me?
    And such sat sending if there is no satellite, how does it work, if there is sending on the cable, why satellite reception at all? And I do not understand how this satellite would send these packets, it only sends to the subscriber's place? How does he know where he lives etc?
  • #34 12778726
    Herbatniczek
    Rate: 8
    The satellite sends all the channels and sends it all over the globe. Your set-top box simply tells you the one you have chosen, but broadcasts (same as on terrestrial TV) are all the time.
  • #35 12778742
    okular766
    Pupil
    Rate: 17
    Well, but how does VOD work? Well, the converter does not send anything from the subscriber?
    I read somewhere that how many people watch illegally encrypted channels, people paying aBO have lags and image stuttering, but what does this have to do with the fact that subscribers do not charge anything, because they only receive whether it is legal or not.
    And the SAT internet also goes with HB? How so does the satellite send packets to a specific place especially for each subscriber?
  • #36 12778770
    andk1eltd
    Level 37  
    Help: 396
    Rate: 375
    okular766 wrote:
    Well, how does VOD work? And the converter does not send anything from the subscriber?
    Satellite has nothing to do with VoD. Everything happens over the Internet, the ordered program is saved in the decoder flash and you play it from there.
    Satellite spreads everything to everyone. From selecting the right things, there are various authorizations on a specific subscriber's equipment.
  • #37 12778780
    okular766
    Pupil
    Rate: 17
    Impossible because a friend has VOD and he has no access to the net.
  • #38 12778802
    andk1eltd
    Level 37  
    Help: 396
    Rate: 375
    There is no VoD on the satellite - strictly speaking. This service is PPV, mistakenly known as VoD. The return "channel" is the telephone, SMS or the Internet - this is how the program is ordered and "unlocked" for a specific subscriber (card) is available 24 hours a day on a separate channel.
  • #39 12778928
    okular766
    Pupil
    Rate: 17
    Well, but how does he get into the apartment?
  • #40 12778955
    Herbatniczek
    Rate: 8
    same as other channels
  • #41 12779093
    okular766
    Pupil
    Rate: 17
    But what about the movie? and how does he know when the subscription wants to watch it
    Because you wrote that the video with VOD flies through the net
    but a friend does not have a net at home and somehow he has VOD via satellite
  • #42 12779130
    Herbatniczek
    Rate: 8
    see yourself Link
    Maybe it's PushVideo or some other concept.
  • #43 12780450
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    e.g. n once (I do not know how after the merger with c +) had a system in which films were loaded on the HDD in the decoder - there is a transponder carousel where you simply transfer movies as files - the decoder collects packages and builds a base but to use you need to have a subscription and / or the so-called return path - without a return patch, you have scratch cards or text messages - you get a one-time code for which you pay.
    Herbatniczek wrote:
    It may be PushVideo ...
    that was exactly what she was using now nc +
    Besides, there are also two-way satellite connections (VSAT) - radio transmission to and from the satellite - usually expensive and requiring additional equipment - it works similar to satellite telephony.
  • Auto mdi/x makes crossover mostly irrelevant
    #44 19095677
    dnetsky
    Rate: 25
    smario11 wrote:
    The speed of a 5e 4-pair cable is 1gbit.
    Whether or not there will be a cross, it is not very important, unless you have 10 years old equipment, then it does matter. Currently, every device has an auto mdi / x
    With this cross, I would read a bit ... Cross is different and Split is different ... Cross was once needed to connect two computers directly Ether-Ether
    Split, on the other hand, breaks 2 pairs in the 8-pair cable and releases them to other pairs ... why?
    and so that the connection has better parameters ... because these pairs are followed by the greatest disturbances
    The effect is that on a cable without split you will not let the communication go above approximately 100m (different devices work differently, therefore approximately) ... but when you do a split, you can release the twisted pair for longer distances
Twisted pair cables, such as Cat 5e, can support speeds up to 1 Gbit/s, while Cat 6 and Cat 6a can achieve up to 10 Gbit/s. The maximum effective length for twisted pair cables is typically 100 meters; exceeding this can lead to signal degradation. Crossover cables are used for direct device-to-device connections, while straight-through cables are standard for connecting devices to switches or routers. Modern networking equipment often supports auto-MDI/MDIX, making the distinction between crossover and straight cables less critical. Internet speeds experienced by users can be influenced by factors such as the quality of the infrastructure, distance to the DSLAM, and the technology used by the Internet Service Provider (ISP), rather than solely the capabilities of the twisted pair cable itself.
TL;DR: A certified Cat 5e twisted pair delivers up to 1 Gb/s over 100 m [TIA, 2018]; "modern ports auto-sense crossover wiring"[Elektroda, smario11, post #12768952] For 10-year-old gear, use a crossover. WAN speeds depend on ADSL line length, not LAN cabling.
Why it matters: Knowing cable limits prevents pointless router swaps when the real bottleneck is your ISP line.
• Cat 5e: 1 Gb/s to 100 m, 100 MHz bandwidth [TIA, 2018] • Cat 6/6a: 10 Gb/s to 55 m (Cat 6) or 100 m (Cat 6a) [IEEE 802.3an] • Ethernet spec maximum segment: 100 m before a switch/repeater [IEEE 802.3] • ADSL2+: up to 24 Mb/s ↓ / 1.4 Mb/s ↑ within ≈3 km loop [ITU-T G.992.5] • Auto-MDI-X appears on NICs/routers since ~2003, removing crossover need [Cisco, 2004]
What data rates can common twisted-pair categories handle?
Cat 5e supports 1 Gb/s; Cat 6 up to 10 Gb/s for 55 m; Cat 6a keeps 10 Gb/s out to 100 m [TIA, 2018][IEEE 802.3an][Elektroda, speedy9, post #12768982]
Does exceeding 100 m really slow an Ethernet link?
Yes. Beyond 100 m attenuation rises; many ports down-shift to 100 Mb/s or lose sync altogether—a typical edge-case failure [Marbis22, #12768959][IEEE 802.3].
Straight-through vs crossover—how do I tell?
Hold both plugs: if orange and green pairs swap positions on one end, it’s crossover. If colours match pin-for-pin, it’s straight. Blue and brown stay unchanged [deus.ex.machina, #12772293].
What happens if I connect two routers with the wrong cable?
Modern hardware uses auto-MDI-X, so link speed stays at 1 Gb/s either way. Very old devices (pre-2003) may fail to link or stay at 10 Mb/s [Elektroda, smario11, post #12768952]
Why is my internet 5 Mb/s when the cable can do 100 Mb/s?
Your WAN uses ADSL over long telephone pairs, not Ethernet. Line length, noise, and DSLAM profile cap throughput, not the LAN patch cable [Elektroda, DVDM14, post #12769099]
Can I upload and download simultaneously on ADSL?
Yes. Downstream and upstream occupy separate frequency bands. Heavy uploads can still choke downloads because ACK packets queue behind data [Elektroda, deus.ex.machina, post #12773757]
Is upload speed even useful for casual browsing?
Absolutely. Each page request and TCP acknowledgment needs upstream bandwidth; zero upload means no new pages load [Elektroda, Herbatniczek, post #12775115]
How do two-way satellite Internet links handle uploading?
VSAT terminals include a transmitter. They send at Ku/Ka-band to the same satellite, but require a powered BUC and cost far more than DSL [DVDM14, #12780450].
Quick 3-step check: is my LAN cable the bottleneck?
  1. Connect PC-router and note link LED colour or OS speed readout. 2. If below 1 Gb/s, swap in a tested Cat 5e/6 patch. 3. If speed stays low, problem is upstream line or NIC settings.
What statistic shows LAN vs WAN speed difference?
A gigabit LAN moves 125 MB/s, yet ADSL2+ tops at 24 Mb/s (3 MB/s)—over 40 × slower [ITU-T G.992.5].
Edge-case: what if connectors are poorly crimped?
Impedance mismatch causes reflections; many ports then fall back to 10 Mb/s half-duplex or drop packets entirely [FlukeNetworks, 2019].
Can I extend Ethernet past 100 m without new cable?
Yes. Add a switch every 100 m, or use PoE extenders or fiber media converters for 300 m+ runs [Cisco, 2020].
