Purmo/Schneider MGU50.505.18Z to Purmo strip 1/2/4 - how to wire?
manter 3171 1
  • #1 12817569
    manter
    Hello, I have a problem connecting temperature controllers to a control strip for floor heating actuators. The strip is a purmo (pic1) where the terminals are
    1-output (in phase)
    2-phase
    4-neutral
    the regulators are from schneider MGU50.505.18Z (external supply) where the terminals are:
    C- common
    NO
    and now what should I connect to what?
    thanks for your help in advance
    • Purmo/Schneider MGU50.505.18Z to Purmo strip 1/2/4 - how to wire? Regulator_1.jpg (280.49 KB) You must be logged in to download this attachment.
    • Purmo/Schneider MGU50.505.18Z to Purmo strip 1/2/4 - how to wire? Listwa.jpg (55.94 KB) You must be logged in to download this attachment.
  • #2 12854616
    IGS
    Help: 44
    Rate: 61
    i didn't quite understand the description of the distributor bar
    you do this
    the thermostats are powered as you have, separately
    (feeding together with the control system would not be wrong either)
    feeding the control phase from the control strip -> C terminal of the controller
    return from the controller to the control strip when it should heat: with NO control phase on -> phase input when it should heat on the strip
    IGS teletechnika i automatyka obiektów
    Bażyńskiego 32 lok 12, Gdańsk, 80-312 | Tel.: 58 XXX XX XX (Show) | Company Website: www.igs-systemy.pl
