How do I record a simulation in LOGO Soft Comfort V6?
Szymek919191 2754 2
  • #1 12889502
    Szymek919191
    I have a question, is it possible to record a simulation in Logo soft comfort v6?
  • #2 12996358
    Meti11111
    Rate: 11
    i am a beginner, so if I write something wrong then please correct ;)
    I have Logo soft comfort v7 and the simulation as such is there - but baaaaavery basic ( on the principle, that when you switch on the input, the bulb lights up ) and nothing else, so there is no crazy ;)
  • #3 14004984
    arkady_pl
    Help: 59
    Rate: 24
    af2f4bb89 Welcome
    It is possible.
    There are quite a few "desktop recording" applications.
    This is how I showed how what I designed works, for example.
    Meti11111 wrote:
    Siem,
    i am a beginner, so if I spell something wrong then please correct it ;)
    I have Logo soft comfort v7 and the simulation as such is there - but baaaavery basic ( on the principle, that when you turn on the input, the bulb lights up ) and nothing else, so there is no crazy ;)
    Not really. You can set the type of input e.g. works if you hold or switches permanently. You can adjust the values of the input signals, you can set the internal values of the counters. You can also simulate cursor key presses(if you have chosen such a model). You can also change the internal values of the counters.
    All in all, you can change quite a lot.
