Temperature measuring device 0-100°C with 12 sensors and remote panel
monter79 2832 4
  • #1 12938067
    monter79
    Help: 31
    Rate: 47
    Hi. I am looking for a device to measure, read and record temperature 0-100 degrees C . The assumptions I would like it to meet:
    1.Controller, with memory, with about 12 measuring points connected to it. possibility of reading via USB or RS or other interface a graph from e.g. 7 days with the accuracy of 10 minutes. There may also be another way, e.g. on an SD card, to convert this into a graph.
    2.A panel elevated 20m from the controller with the ability to read the temperature from each sensor. A reasonably aesthetically pleasing design.
  • #5 13300541
    kszysek
    Help: 26
    Nettemp.co.uk on rpi, for 200pln you have exactly what you are looking for.
