Interference with roller shutter drive radio receivers and 16-channel remote?
misopi 6492 15
Why do some roller shutters only respond once after a power cut and then stop reacting to the remote, and how can this be fixed?
The likely cause is a failed receiver capacitor integrated in the roller-shutter tube, not radio interference, and the fix is to replace that capacitor [#13165737][#13185911] Manufacturer support reportedly suggested the capacitors may have been damaged by an overvoltage [#13127276] The symptom of the shutter working once after switching the fuse off and on fits this kind of receiver fault, which is why the remote works only until the next command cycle [#13165737] One user paid 250 PLN to repair three shutters, including dismantling and reassembly, and afterward they worked correctly from the master remote and collective channels [#13182602] Another poster confirmed that this matched the service diagnosis [#13167258]
  • #1 12953695
    misopi
    Rate: 9
    Welcome,
    i've been experiencing quite a problem with the 'anti-burglary' roller shutter drives in the house for a few weeks now. Three of them, operating on different electrical circuits have stopped responding to the remote control. The trouble is that during the construction phase of the house I let myself be persuaded by the RKS box technology above the windows, as a result of which I only have access to the roller shutters and drives including the radio from the inside. For aesthetic reasons, in order to avoid conflict with my wife, I consciously decided to cover the inspection boxes with K-G board and to plaster and paint them. Access to them now requires more renovation. The installation is less than three years old.
    The only option for controlling the roller shutters is a 16-channel remote control. The problem I am currently battling has occurred once in the past, but it only affected one roller shutter and resolved itself. Now three roller shutters on the same day have stopped responding to the remote, both on the individual channel and on the collective channel (to operate all the roller shutters simultaneously). It is not a question of distance, as normally the remote has a range of several metres, the signal coping with walls. In the three unlucky roller shutters, it does not even catch from several centimetres. However, I have noticed that disconnecting the power supply for a few seconds (switching off the fuse on the circuit) makes the roller shutters respond to the signal, but only once - I can lower them, but I can no longer stop them in the middle or raise them without temporarily cutting off the power supply again. So it is unlikely that the fault lies with the remote control. Initially, I thought it might be some device, a transmitter interfering with the frequency (three different roller shutters went off on the same day). However, I have no idea what this could be. Although the WiFi router was replaced not so long ago, it had been working flawlessly for several months. I even tried switching it off, the fault persisted.
    Do any of you have any ideas what could be causing this and how to try to remedy the problem?
    Michael
    PS. Apologies, but the matter is so unusual as to its subject matter that I will take the liberty of repeating the question in the Beginner's Radiotech forum
  • #2 12954124
    telbod
    Level 32  
    Help: 163
    Rate: 240
    Do you have any data on what the controller is? How are the drives connected?
  • #3 12969646
    misopi
    Rate: 9
    The controllers and drives are from Success.
  • #4 12969689
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    Do we have to search or guess for you what model of controller and control unit it is?
  • #5 12982567
    misopi
    Rate: 9
    Thank you for pointing this out, unfortunately getting the information out of the company who fitted the blinds for me is not easy. I am trying to establish this.
    Michael
  • #7 13125868
    robertod
    Did you manage to remove this fault?
    I have exactly the same with the same equipment, when I disconnect the power with the fuse I can raise and lower the roller shutter, but only once. The next time, I also have to switch off the power supply.
    If you have solved the problem, was it necessary to renovate the house? Did you have to get to the inspection boxes ??
    Best regards
  • #8 13127276
    misopi
    Rate: 9
    Welcome,
    unfortunately I have not received any constructive advice. I even contacted the manufacturer's service department. They were unable to help remotely. They suggested that the capacitors might have "sprinkled" due to some kind of overvoltage. So it is unlikely to be an interference issue.
    I have decided against an overhaul for the time being. As long as the fuse trick works I probably won't dare. However, I will certainly consider changing the type of roller shutters, if possible, to ones with external access. I think I'll be able to squeeze them into the insulation (polystyrene), while the RKSs will be "foamed" to prevent the wind from blowing.
    Michal
  • #9 13131299
    robertod
    I fortunately have the boxes just on the outside in polystyrene. In retrospect, I consider this to be a sensible solution.
    I also called the manufacturer's technical department and they weren't able to diagnose much either due to the distance.
    A repairman is due to come to repair it next week and if the fault can be rectified I will let you know.
    In your case, do the roller shutters not work at all?
    In my case, 3 out of 8 do not work and of these 3, one sometimes works and sometimes does not.
  • #10 13146748
    misopi
    Rate: 9
    In my case, three out of fifteen do not work without a momentary power cut. Please let me know how I can diagnose the fault. As I wrote earlier in my case, getting to the boxes involves a major overhaul.
    Best regards,
    Michał
  • #11 13165737
    robertod
    fault cleared, so far in one roller shutter, but same issue with the rest.
    the fault in our case relates to the receiver capacitor, which is integrated in the roller shutter tube.
  • #12 13167258
    misopi
    Rate: 9
    Thanks for the information. You have confirmed the remote diagnosis of the service.
  • #13 13169274
    maestro255
    I also had a similar problem from time to time but it usually went away on its own.
    I thought it was a weak remote control battery, I replaced it but that's not it.
    E.g. today no roller shutter works.
    Please let me know how much it costs to repair these capacitors.
    Michael
  • #14 13182602
    robertod
    For the 3 repaired roller shutters I paid 250 PLN and a bit of joint work to take everything apart and put it back together.
    It works great flows from anywhere on the "mother" remote and on the collective channels.
    Good luck and best regards
  • #15 13183330
    maestro255
    Thanks for the info but I'll ask one more question. Did this repair involve actually soldering some capacitors or was it a simple replacement of the relay that controls the motor?
    Greetings
  • #16 13185911
    robertod
    It was an actual capacitor replacement.
    That's what I was told by the friend who did it, and since he's quite a professional and I trust him, I have no reason not to believe Anki.
