Connecting 5W Polycrystalline & 10W Monocrystalline PV Panels with Charging Regulator
PoczątkujacyODN 34725 31
Can I connect a 5W polycrystalline PV panel and a 10W monocrystalline PV panel in parallel to the same charge regulator?
Yes—because the panel voltages are very similar, you can connect them in parallel and nothing bad should happen [#13102548] With this kind of low power, the main effect is some loss of available power, and the higher-voltage panel will be pulled toward the lower-voltage panel’s operating voltage [#13332284] If you want to reduce backfeed between panels, you can put a diode in series with each panel’s positive lead [#13102615]
  • #32 18039771
    kmferg
    Like this topic, so I'm sticking.
    How to connect it, monocrystalline panels, in series or in parallel, which will be more optimal.
    With parallel, which diode to use (? A)
    The controller is TRACER MPPT 40A.
    12V installation (motorhome) and one AGM 100AH battery for now (there may be a second one, and switching to charging the starter battery).
    1. Pmax = 288W; Vmp = 32.52V; Imp = 8.91A; Voc = 38.52V; Isc = 9.40A
    2. Pmax = 264W; Vmp = 31.80V; Imp = 8.29A; Voc = 37.56V; Isc = 8.70A
✨ The discussion revolves around connecting a 5W polycrystalline photovoltaic (PV) panel with a 10W monocrystalline panel and a charging regulator. Users express concerns about compatibility due to differing voltages and currents. It is generally agreed that connecting panels with similar output voltages in parallel is feasible, although some caution against significant voltage differences. Suggestions include using diodes to prevent backflow and potential damage. Additional queries arise regarding connecting multiple panels of different types and voltages, with advice emphasizing the importance of matching voltages and currents to avoid inefficiencies and damage.
TL;DR: A 10 V MPP mismatch can slash harvest by 15–25 % [NREL, 2020]. “Just connect them in parallel with diodes” [Elektroda, prose, post #13331971] Panels that differ ≤ 6 % in voltage work fine when paralleled. Why it matters: Mixing modules wrongly wastes power and may stress your charge controller.
• Safe voltage-mismatch band: ≤ 10 % of lower panel Vmpp [NREL, 2020] • Schottky blocking diode drop: 0.3–0.7 V at 25 °C [ON-Semi, DS] • 10 A/45 V Schottky costs ≈ €1 retail in EU [Mouser, 2024] • Typical PWM regulator reverse-current limit: < 1 mA [Victron, 2023] • Wiring loss target: < 2 % at STC per IEC 62548 [IEC, 2016]
Can I mix a 5 W poly (16.5 V) and a 10 W mono (17.5 V) panel on one regulator?
Yes. Their Vmpp differ by only 1 V (≈ 6 %), so parallel wiring is safe. Expect the higher-current 10 W module to supply most of the amps; total power stays near 15 W [Elektroda, putas, post #13102548]
Do I need blocking diodes when paralling different panels?
Add one series Schottky per positive lead. It stops night-time back-feed and isolates a shaded or faulty module [Elektroda, prose, post #13102615] Choose 1.3× Isc rating; a 10 A/45 V part suits small 12 V arrays [ON-Semi, DS].
Series or parallel: which is better for mixed modules?
Parallel keeps each panel near its own Vmpp, so power loss is minor when voltages match. Series raises voltage for long cable runs or a 70 V heater but forces current to the lowest panel value [Elektroda, prose, post #13334436]
How much power do I lose if Vmpp differs by 10 V?
Field tests show 15–25 % output drop because the higher-voltage panel back-biases to the lower module’s Vmpp [NREL, 2020]. That is why the 25.7 V and 35.4 V modules should not share a bus [Elektroda, putas, post #13331679]
Will mismatched current damage panels?
No. A photovoltaic module behaves as a current source. The weakest current sets the string limit, but nothing overheats unless reverse-biased, which the diode prevents [Elektroda, CzystyZYSK, post #13344365]
How do I wire a 120 W (25.7 V) with a 180 W (35.4 V) panel to a 24 V heater?
  1. Solder a 10 A Schottky on each ‘+’. 2. Parallel the outputs. 3. Connect directly to the 24 V/200 W heater. The 180 W panel will run slightly below Vmpp, losing < 10 % power [Elektroda, prose, post #13332284]
What happens in the edge case when one panel is fully shaded?
The shaded module’s voltage collapses; the diode blocks reverse current, so only its own ~0 W is lost. Without the diode, the lit panel would push up to Isc through the shaded one, risking hot-spot failure [IEC TR 60904-7, 2019].
Which diode rating should I choose for a motor-home array (max 9.4 A)?
Select at least 1.25× Isc, so pick a 10–15 A part with 40–60 V reverse rating. A TO-220 Schottky on a small heatsink keeps junctions < 85 °C at STC [Elektroda, theo33, post #17880799]
Can my Tracer MPPT 40 A handle two 288 W and 264 W panels in parallel?
Yes. Combined Isc ≈ 18 A, well below the controller’s 40 A input limit. Keep array Voc under 100 V (it’s 38–39 V per panel) [Elektroda, kmferg, post #18039771]
Is it worth adding a wind turbine instead of a second mis-matched panel?
For similar cost per watt, adding a panel yields > 20 % more annual energy than a 300 W micro-turbine unless average wind exceeds 5 m/s [Fraunhofer, 2022]. “Panels are cheaper and more reliable” [Elektroda, Etoo71, post #17900378]
How do I safely parallel two small panels?
  1. Verify Vmpp values differ ≤ 10 %. 2. Mount 10 A Schottky diodes on each positive lead. 3. Tie negatives together, tie diode outputs together, then to regulator input. Finish with a 20 A fuse near the controller. Total time: under 10 minutes.
What if my controller shows low charge after adding a second panel?
Check for a damaged module first. An open-circuit panel gives zero current even in sun, as in post #17882638. Replace or repair before blaming the regulator [Elektroda, Etoo71, post #17882638]
