Two transmitters for one Anslut 433.92 MHz receiver, 2 receivers in 1 room?
radam5 3879 14
Can I use one 433.92 MHz Anslut receiver with two transmitters to control two wall switches, and can two receivers work independently in the same room?
Yes: the thread confirms that one Anslut receiver can be paired with two transmitters, and the original poster later reported that one receiver plus two transmitters worked in practice to switch the stair lights. The receiver is self-programming, so you assign codes by bringing the remote close, holding the receiver’s programming button for 3 seconds, and then pressing the remote’s ON button. The same setup also supports independent operation of multiple receivers as long as each receiver is programmed separately with its own transmitter code. The OP also reported the range was acceptable, with one transmitter on the 2nd floor and the receiver near the basement ceiling. [#13318708] [#14500521]
  • #1 13300313
    radam5
    I am looking for a wireless receiver (preferably flush mounted) with which to control two wall switches.
    I have found such devices in Jula by Anslut. However, I am not sure if they will be suitable for my idea.
    Description of the receiver
    "Flush-mounted remote control receiver
    control
    Remote-controlled and self
    programming receiver with on/off function and 67 million possible codes
    off function and 67 million possible codes.
    For indoor use. Range:
    up to 30 metres. Maximum load:
    1000 W. Frequency: 433.92 MHz. 230 V.
    W:52xW:35 mm. "
    The instructions say : "Self-programming" and "Code assignment. Bring the remote control close to the receiver, press the programming button on the receiver for 3 sec,
    and the green LED on the receiver starts flashing slowly. Press the ON(ON) button on the remote control".
    Will this device meet my requirements?
    Second question, can two such receivers operate independently in one room?
    i am enclosing links to the entire manual
    switch
    in Polish from page 6 Link
    Receiver
    in Polish from page 8 Link
  • #2 13300347
    boguslaw robak
    Help: 35
    Rate: 53
    Hi I have fitted such modules from zamel maybe this will help you .
  • #3 13300475
    radam5
    They don't have wall switches but remote controls
  • #4 13300572
    boguslaw robak
    Help: 35
    Rate: 53
    I personally bought at my place in Tychy there are battery operated and mains powered surface and flush mounted ones
    Added after 8 [minutes]:
    I found exactly this Zamel Exta Free.
  • #6 13318708
    radam5
    I can see that there is a lot to choose from.
    I have been looking on the internet and have not before found these companies you state.
    However, I got a reply on these from Anslut that it is possible to pair 2 transmitters to one receiver.
    They are the cheapest and I have ordered for a trial. When they arrive I will write whether this is actually the case.
    P.S. An additional question on a different subject.
    Where can I get reed switches (preferably in a housing) which break the circuit when magnets are applied and close the circuit when they are moved away? Seemingly everything indicates that they are NC but I ordered one and it works the other way round.
  • #7 13319156
    boguslaw robak
    Help: 35
    Rate: 53
    probably satellite has.
  • #8 13319198
    tomix
    Help: 7
    Rate: 99
    radam5 , just as the colleague above stated. They are on Allegro from Satel for £13 per set (reed switch + magnet). Look for K-1/K-2/K-3 and 2E
  • #9 13319868
    radam5
    thanks, but i'm afraid this one will also work the other way round, i.e. it will close the circuit when the magnet is applied. and i want it the other way round.
    i bought a mc21c and it doesn't work the way I wanted, despite the assurances of the seller
  • #10 13329761
    IGS
    Help: 44
    Rate: 61
    i am writing from memory, you can easily find these manufacturers/distributors and select solutions
    1. ELMES receivers, transmitters to be installed in any electrical switching equipment
    battery-powered, and probably also phase-powered depending on the version
    2. ZAMEL transmitters integrated with switches
    3. INEL Polish manufacturer of roller shutter automatics, has a range of radio control solutions for installation into fixtures
    4. ELKO, probably a Slovakian product, ready-made automation solutions, including wireless solutions mounted in boxes behind fixtures - sold in Poland min. by EFP Polska
    IGS teletechnika i automatyka obiektów
    Bażyńskiego 32 lok 12, Gdańsk, 80-312 | Tel.: 58 XXX XX XX (Show) | Company Website: www.igs-systemy.pl
  • #11 14500521
    radam5
    The cheapest anslutes are working so far. One receiver + two transmitters. They switch on the stair lights.
    The range is also ok. One of the transmitters is on the 2nd floor and the receiver in near the basement ceiling
  • #12 14503400
    wojtek_1010
    Help: 15
    Rate: 12
    The reed switches used in security systems (i.e. Satel, for example) are of the NC type, i.e. short-circuit when the magnet is approached, open when the magnet is moved away. I also used to look for a reed switch like you need and was unsuccessful. i "reversed" the operation using a relay.
  • #13 14503794
    radam5
    I also gave up.
    I even combined with two magnets but it's hard to get the right forces.
  • #14 14504691
    wojtek_1010
    Help: 15
    Rate: 12
    I was reminded, I once serviced machines where the housings were protected, against opening, by reed switches which had NC and NO contacts. Hamlin company. Machines (envelope machines) from Pitney Bowes. Availability may be an issue.
    See here:http://www.hamlin.com/specsheets/59145_59150.pdf - small table on the right next to the drawings of the enclosures.
  • #15 14590927
    Jacek Rutkowski
    Help: 69
    Rate: 275
    Reed switch CKS-53 Reach:30mm; External dimensions:64x13,6x13,8mm; Contacts: SPDT is available e.g. from TME at 17.90 net/unit, they have over 2000pcs of this in stock.
