VELUX KLR 200 - How to get control of your roller shutters with a single remote control.
tooomala 4506 6
  • #1 13375914
    tooomala
    I am at the stage of building a house, specifically ordering windows and roller shutters for them. The house is already covered and has 15 Velux roof windows fitted all of which have roller shutters installed and one of which is electric opening. I got the roller shutters and two KLR 200 touchscreen remote controls and one controller to operate five roller shutters, I need to buy 2 more as a result but that is not the problem. I still have 9 windows with roller shutters on the ground floor, but for two or three of them I will have to use two motors each due to the large width of the window.
    I know that I should use the IO homecontrol roller shutter control on the ground floor, but one motor costs £900 and I will need 11 or 12 of them :/
    Is there a solution that will allow me to control everything from one remote control, the one from Velux ? It can control up to 200 devices.
    Please give me some advice and hints on the cheapest way to put this together.
    Regards.
  • #2 13376250
    ekmir
    Help: 18
    Rate: 407
    Would this remote control be each roller shutter or a group of roller shutters ?
  • #3 13376759
    tooomala
    Each roller shutter separately.
  • #4 13376804
    ekmir
    Help: 18
    Rate: 407
    You could try using a KLI 110 or KRD 100 wall-mounted keypad (adaptor for io-homecontrol platform)
  • #5 13378160
    tooomala
    As for the second solution, it's not very cost-effective if you add this device to any engine of even decent quality then the price will come out similar, while the first solution I don't know how it's going to help me use the remote controls from Velux.
  • #6 13378238
    ekmir
    Help: 18
    Rate: 407
    These are reverse solutions.
  • #7 15252295
    tooomala
    Better late than never, so I am writing ;)
    The solution is to order roller shutters with SOMFY motors and only certain series supposedly. Unfortunately I can't remember what series it is as I commissioned the roller shutter supplier to do this.
    Regards and closing the topic.
