How to build a circuit to control the gate via an intercom with a 443.92MHz remote control?
hrns6 3906 4
  • #1 13394094
    hrns6
    Warm welcome,
    I would like to ask you for help in creating a simple circuit to control the entrance gate to the housing estate. The matter is that making a remote control at the manufacturer of the estate gate costs about 250 PLN (I do not know why the company wants so much, I tried copying to a new remote but it did not give anything). The gate can also be opened via the intercom (appropriate button).
    So I wondered if it would be possible to create a radio receiver which, plugged into the intercom, would open the gate, e.g. using a transistor. Only it needs to be controlled somehow.
    I have a remote control with a frequency of 443.92MHz.
    The distance is also important, it is about 100m.
    I think it is a simple matter for experienced electronics engineers, so please help, I have searched on the internet, but found nothing understandable for me.
    I am counting on your help and thank you in advance =)
  • #2 13394155
    nikusert
    Help: 699
    Rate: 1754
    Buy a radio link for your remote control,and attach it to the intercom button.A good radio link + maybe a small antenna, should work .A bit expensive for the remote control.Is the other remote control the same?
  • #4 13394896
    nikusert
    Help: 699
    Rate: 1754
    For example, yes,(the one in the picture is a two-channel one) a single-channel one will suffice.As long as it will work with your remote control.Your remote control is 433.92MHz rather than 443.92MHz.If I am right then look on the ELDRIM website.
  • #5 13432828
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    If I have understood correctly, do you want to control a receiver in your flat 100 m away from the gate by remote control?
    If so, forget about a "normal" radio line and a normal remote control.
    You need a radio line of at least 200 m, and the most likely distance would be 500 m.
