Radio control of the circulation pump from 3 points and timer
baniol79 1962 3
  • #1 14031490
    baniol79
    I cannot find such an idea on the forum.
    I'd like to do something about the energy loss for hot water and I've come up with something like this to have the pump radio-controlled from three points. 2 bathrooms and a kitchen.
    i would also like to add a time switch. (I enter the bathroom, press a button, undress and have hot water and e.g. after 5 minutes the timer switches off the pump). I need a device such as a socket controlled by 3 buttons wirelessly.
    thank you in advance for your reply
  • #2 14032219
    spinacz
    Help: 1204
    Rate: 2651
    Staircase automation AS-212
    Radio-controlled relay receiver RS-407M
    Radio-controlled relay RS-N1 transmitter
    Simply connect accordingly and it will work as you wish.
  • #3 14032250
    baniol79
    and which company, if you don't mind me asking
  • #4 14032789
    spinacz
    Help: 1204
    Rate: 2651
    Buddy, if you are given the symbols of the appliances and you ask what company they are from, then forgive me and with all due respect, but you'd better not touch the installation because you won't connect it anyway.
