LOXONE-DMX-PWM - Flickering of the LED strips after a few minutes of operation
HAIDI78 3126 7
  • #1 14228962
    HAIDI78
    Hello everyone.
    Well, I would like to describe a problem.
    I have eight led strip circuits connected to a LOXONE DMX-PWM controller (12V-24V 3X3 CHANNELS). The Pwm controller is powered by 12v DC and the strips are connected to the led amplifiers (due to their high power) via transformers with the appropriate power (20% reserve).Transformers with a power of 150,250,320
    After switching on whichever circuit and whatever intensity the leds are at, after a few minutes they flash (approx. 0.3s) at full power and continue to flash every few minutes.
    Switching on all the circuits, regardless of the intensity, the flashing is on all the circuits separately only in time intervals and sometimes two or three circuits flash at the same time.
    Perhaps someone has an idea about this?
    Please give me an answer on this matter.
    Regards
  • #2 14309322
    iF-Jimi
    There can be several reasons for this. Chinese power supplies of poor quality, a faulty LED module, a faulty DMX module. I don't know Loxone personally, but for me the use of DMX protocol in building automation is a misunderstanding. It's an outdated protocol developed for stage lighting, and it still works well there, but I wouldn't implement it at home. Communication is unidirectional, so the controller never knows if the signal has arrived without error. If the cable is unshielded, the controller is in one place, the DMX dimmer module in another, and the cable goes past some device that generates some kind of pulse, this can also be the cause. Good quality shielded cables are used for DMX, usually low capacitance audio cables.
  • #3 14310575
    HAIDI78
    iF-Jimi wrote:
    There could be several reasons. Chinese poor quality power supplies, faulty LED module, faulty DMX module. I don't know Loxone personally but for me the use of DMX protocol in building automation is a misunderstanding. It's an outdated protocol developed for stage lighting, and it still works well there, but I wouldn't implement it at home. Communication is unidirectional, so the controller never knows if the signal has arrived without error. If the cable is unshielded, the controller is in one place, the DMX dimmer module in another, and the cable goes past some device that generates some kind of pulse, this can also be the cause. For DMX, good quality shielded cables are used, usually low capacitance audio cables.
    The only thing that could be the cause is the lack of a shielded cable between DMX and PWM
    Thank you for your reply
  • #4 14432214
    OSP
    User under supervision
    Hello as far as I remember there is only 50W per channel maybe you have exaggerated the watts.
  • #5 14432756
    HAIDI78
    OSP wrote:
    Welcome as far as I remember there is only 50W per channel maybe you have exaggerated the watts.
    Each channel goes through a 240w amplifier
  • #6 14602447
    zibigu
    You were writing about transformers ...- transformers are not used for leds but power supplies....
  • #7 14611038
    HAIDI78
    These are power supplies for led tapes
  • #8 14611887
    homelogic.pl
    Basic diagnostics are in order. Unplug the amps and connect a few metres directly. Are they still flashing? If not, you have cables and amplifier to check. If yes, then the DMX module should be replaced. They have recently released new models of controllers with RGBW.
