Controlling Elbro AB440R sockets via Raspberry Pi GPIO - how to do it?
kwoka2 1371 1
  • #1 14259871
    kwoka2
    Rate: 8
    I have some radio controlled sockets and remotes for them,
    These are sockets and remotes made by Elbro, remote control model AB440R.
    I have a question, is it possible to control via RPi these remotes?
    Through the GPIO in the RPi?
    Currently I have the possibility to control ordinary relays via GPIO but to control the above mentioned remotes only a momentary short to ground is needed.
    Unfortunately I do not have enough knowledge to do this.
    Please help me in this matter.
    thank you in advance
    Regards: Damian
  • #2 14265086
    Gunslinger
    Level 30  
    Help: 114
    Rate: 461
    The easiest way is to take the remote control apart and see if it can be soldered on both sides of the button. And then e.g. relay and GPIO.
