Choosing Affordable SMD Soldering Microscope: Height, Optics & DIY Tripod Modifications
MasMas 30822 32
Is this affordable microscope suitable for SMD soldering, and is the working height and optics good enough for using a soldering iron?
Yes—this cheap optical binocular microscope is considered suitable for SMD soldering, and several users said the working height is enough to use a soldering iron under it, while the main limitation is the stand/work area rather than the optics themselves [#15302043] [#15637551] One user reported soldering 0.5 mm LQFP and even 0805 parts with about 6.5–7 cm of working distance, finding 20x magnification sufficient and the built-in lamp useful [#15302043] [#15392546] [#15637551] The biggest practical problem is the stock base/PCB placement, so a DIY stand or modified tripod is recommended for larger boards; keeping the height-adjustment mechanism helps [#15637551] For hobby use or less frequent soldering, the thread’s consensus is that this microscope is good value, but if you solder all day in repair/service work, a more expensive professional microscope with a larger working area, head tilt, and variable magnification is better [#15392546] In the later discussion, optical stereo microscopes were also judged clearly better than electronic LCD microscopes because they give real 3D depth and avoid exposure/distance problems [#20585796] [#20586724]
  • AD407/Pro lens, tripod, and HDMI notes
    #31 20590082
    slavo666
    Help: 37
    Rate: 390
    AD407/Pro has a 30mm metal lens with a thread for which you can buy accessory lenses (Xit XT30WAB 30mm 0.43X). As for the size of the screen, 7" is quite sufficient. All tripods of these microscopes are not suitable for viewing large plates, because they are blocked by the adjustable column. You either have to use them the other way round or make your own, e.g. on the basis of a telescopic monitor holder.
    A lot of people use electronic microscopes and look from the monitor, it is an individual matter. It definitely takes some getting used to in the beginning. See, for example, https://www.youtube.com/@NorthridgeFix or https://www.youtube.com/@StezStixFix
    I mainly use them to record close-ups for movies, because they are handy. The most pleasant is in my opinion the good old AD407. The tripod still needs to be modified by yourself. AD407 feeds the image on the monitor and HDMI simultaneously. The 249S-M turns off the monitor when connected to HDMI.
  • Higher-resolution microscope camera may be unnecessary for soldering
    #32 20592517
    bachin
    Rate: 59
    OK, thanks, but will it be a big mistake if I buy with a larger screen, e.g. Andonstar AD209 10 "(https://pl.banggood.com/Andonstar-AD209-10-inch-Digital-Microscope-1080P-adjustable-LCD -display-Microscope-for-soldering-Microscope-Phone-watch-Repai-p-1985979.html?akmClientCountry=PL&cur_warehouse=CN)?
    The difference is not very big, and those 3 extra inches will be a plus, not a minus.
    I'm also considering something like this https://pl.banggood.com/HAYEAR-Full-Set-34MP-...Camera-HDMI-USB-Outputs-180X-C-mount-Lens-60- LED-Light-Big-Boom-for-PCB-Repair-p-1955312.html?rmmds=detail-bottom-viewalsoview&cur_warehouse=CN&trace_id=59521684915616993
    and adding a lcd monitor on top.
    The question is whether such a powerful camera is necessary for soldering and will it matter? Can you make a comment?
    Added after 1 [hours] 46 [minutes]:
    Or something like this solution https://pl.banggood.com/HAYEAR-2K-51MP-1080P-...mera-0_5X-Eyepiece-Adapter-30mm-or-30_5m-Ring -for-Phone-PCB-Repair-p-1705003.html?rmmds=detail-left-hotproducts&cur_warehouse=CN&trace_id=59521684915616993
    will it be better? The camera has a much higher resolution, the money is similar, and a 10-inch monitor and two illuminators are pennies?
    Such equipment beats all toys and closes the topic.
  • Blue-camera set has better optics than pink one
    #33 20592859
    tplewa
    Help: 222
    Rate: 1009
    You're not reading properly :) This camera is the same apart from the color :) They are neither 34MP nor 51MP ... Mine described as 38MP has 60MP in the menu:
    I was making fun of this and I gave this photo in the thread to which I gave a link together with the packed photos to see.
    What sensor in the camera has a real resolution is difficult to sense, but certainly not as shown in the pictures, it is impossible to tell because the software does interpolation - maybe 16MP is real, but there is no certainty. Let's add that 2MP is really enough for FullHD work...
    Now as for this set, the first one is better. For this you will have to buy an illuminator + tripod. Another thing in the first one (with the blue camera) the optics look much better.
    Anyway, regarding the pink one, if you look at the photos, you can see that it is probably dedicated as a camera for an optical microscope that does not have a third track for the camera (you put this optic in place of the eyepiece in the microscope).
The discussion revolves around selecting an affordable SMD soldering microscope, focusing on height, optics, and potential DIY modifications. Users express concerns about the working distance, with suggestions that less than 7 cm may be inadequate for soldering tasks. Various magnification levels are debated, with some users finding 20x sufficient for small components like LQFPs. Alternatives to traditional microscopes, such as using smartphones for magnification, are also mentioned. Users share experiences with specific models, including the TPL ICD 20x BINO and Andonstar series, highlighting the importance of working area and the ability to modify tripods for larger PCBs. The conversation emphasizes the balance between cost and functionality, with recommendations leaning towards optical microscopes for better image quality despite the convenience of electronic models.
TL;DR: A 20× stereo scope with > 70 mm working distance lets you solder 0.5 mm-pitch parts; “anything under 7 cm is not enough” [Elektroda, freebsd, post #15100242]
Why it matters: The right height and optics prevent burned lenses, shaky joints and wasted budget.
• Recommended working distance: ≥ 70 mm (2.8 in) [Elektroda, freebsd, post #15100242] • Practical magnification for electronics: 10×–30× [Elektroda, MasMas, post #15302043] • Budget stereo microscope price: PLN 160–250 (≈ €35–55) used [Elektroda, tplewa, post #15303189] • 0.5× Barlow lens lifts distance to ~160 mm and halves magnification [AmScope, 2022] • Andonstar AD407 streams HDMI and on-board LCD simultaneously [Elektroda, slavo666, post #20590082]
Can I expand the tiny working area of a cheap scope?
Yes. Remove the factory base, bolt the column onto a 40 cm flat steel bar, and trim the post so focus still reaches the PCB. This mod lets any board slide freely on the desk [Elektroda, MasMas, post #15637551]
Which Andonstar model keeps its own screen on when HDMI is connected?
The AD407 (and AD407 Pro) mirror to HDMI and the built-in 7" display simultaneously. The 249S-M blanks its LCD once HDMI is active [Elektroda, slavo666, post #20590082]
Do I need a Barlow lens, and which one?
A 0.5× Barlow is the most useful: it doubles working distance to roughly 150–160 mm and widens the field, perfect for hot-air work [AmScope, 2022]. Higher-power (2×) lenses shrink the area and are rarely used in repair [Elektroda, tplewa, post #20384447]
Can a smartphone camera replace a microscope?
Not for fine work. Phone zoom gives only 5–7× effective magnification and no stereo depth [Elektroda, introder00, post #15121081] Components smaller than 0603 appear blurred, and hand stability becomes the limiting factor.
What’s an edge case where microscopes fail?
Scopes with plastic objective sleeves can warp when hot-air exceeds 200 °C. One user reported melting during reflow because the lens sat only 60 mm above the board [Elektroda, tplewa, post #20586724]
How do I build a quick flat-bar stand for larger PCBs?
  1. Unscrew the column from the stock base.
  2. Center-bolt it onto a 400 × 40 × 5 mm steel flat bar elevated 25 mm.
  3. Trim column height so focus covers 70–120 mm range. This 15-minute mod fits laptop motherboards easily [Elektroda, MasMas, post #15637551]
Does an SMD soldering certificate improve job prospects?
Employers value proven skill more than paid certificates; hands-on practice on scrap boards beats short courses, says an experienced technician [Elektroda, tplewa, post #20384447]
What eyepieces suit glasses wearers?
Choose wide-field WF10×/20 eyepieces with rubber cups that lack side baffles. They let you keep prescription glasses on without vignetting [Optics-Trade, 2021].
