Which wires for central heating wiring with underfloor heating and radiators?
kajserr 2115 6
  • #1 15308478
    kajserr
    Rate: 8
    I'm doing alarm, automation and other utility installations at a friend's new build. He asked me about the wiring of the central heating.
    What wires, where and how to lay it ?
    There will be underfloor heating and regular radiators, gas furnace. There will also be a recuperator, but I don't know if this has anything to do with the central heating (is there a need to combine this into one system).
  • #2 15308507
    mawerix123
    Help: 482
    Rate: 951
    And you know the layout and types of equipment :?: here you need coordination with the heating and ventilation contractor.
  • #3 15308625
    kajserr
    Rate: 8
    hmm... my friend probably doesn't know himself, and I don't have any contact with plumbers... and sample wiring ? what to ? what to look for in a central heating system ? ? in general he will probably want to have everything wired up in a nexwell or something simpler, but the installation is worth preparing on the fly ;)
    mawerix123
    Help: 482
    Rate: 951
    kajserr wrote:
    and I have no contact with plumbers
    But the builder probably has contact with them so it might be good to meet on site to make initial arrangements.
    Example of a recuperator scheme --> http://www.pro-vent.pl/rekuperatory-mistral-max-schematy,0.html
    One of the simpler schemes of central heating control. --> http://muratordom.pl/instalacje/ogrzewanie-gazowe/instalacja-pod-kontrola,26_3720.html for this you need to anticipate floor control.
    Or maybe something wireless --> http://fibarobialystok.pl/danfoss/danfoss-link
    kajserr wrote:
    generally you will probably want to have everything wired into a nexwell or something simpler
    It would be worth checking with the distributor of your chosen system.
  • #5 15311237
    kajserr
    Rate: 8
    Thanks ;) I'll probably be there on Saturday, have a chat, think about the subject and write up what exactly will be fitted there.
  • #6 15311332
    mawerix123
    Help: 482
    Rate: 951
    It would be good to extract the schematic/design from them to know and be able to use when selecting the controls.
  • #7 15316641
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 670
    kajserr wrote:
    Thanks <br/span>;) I'll probably be there on Saturday, have a chat, think about the subject and write up what exactly will be fitted there.
    Maybe to start with, not so much what will be fitted there, but what expectations the customer has.
    For example, is he interested in zone heating - the possibility of controlling each room (or group of rooms) separately by means of building automation, control through a system with mixers (control from a boiler through additional expansion modules) or will he remain with manual regulation on rotameters in distributors or thermostats on radiators.
