Bimetallic thermostat for outdoor power supply, operating from -10°C
Pocieszny 2295 6
  • #1 15340768
    Pocieszny
    Help: 229
    Rate: 263
    I have a certain device located outdoors. It contains a power supply which, according to the manufacturer, can operate from -10°C. I want to protect it from switching on below this temperature. Are there any bimetallic thermostats for such low temperatures? Electronic ones tend to fall out as they require a power supply and I want to cut it off below this temperature limit.
  • #2 15340803
    karolark
    Help: 702
    Rate: 2518
    How about the other way round - an enclosure with a small 5-10W heater?
  • #3 15340822
    Pocieszny
    Help: 229
    Rate: 263
    If someone turns on such a frozen power supply (pulsed) in a 20-degree frost, the heater may not have time to heat it up before it fires something :) I also don't want to permanently connect a 230V heater, because why should it heat non-stop.
  • #4 15340841
    oskar777
    Help: 76
    Rate: 243
    Hello, then make a thermostat with a hysteresis for the heater from -9 degrees it starts heating after -8,-7 it turns off
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #5 15340842
    DJ ANNUS
    Help: 108
    Rate: 354
    Turn the heater on below about 10'c.
  • #6 15340847
    Pocieszny
    Help: 229
    Rate: 263
    I've just found a power supply that according to the manufacturer can withstand -30°C, I think I'll put one in there and there will be no need to combine with heaters.
  • #7 15343412
    kajron
    Help: 109
    Rate: 159
    the easiest way is probably to use a contact thermometer e.g. Link
