[Solved] [CBU/BK7231N] AVATTO GDS16 WiFi relay module - Sensor Problem
gobbirock 366 3
  • Sensor pin likely needs different GPIO mode
    #1 21909526
    gobbirock
    Hi everyone, I bought a garage door opener from Avatto GDS16:
    [CBU/BK7231N] AVATTO GDS16 WiFi relay module - Sensor Problemcase.png (5.23 MB)You must be logged in to download this attachment.
    [CBU/BK7231N] AVATTO GDS16 WiFi relay module - Sensor Problemside_1.png (5.58 MB)You must be logged in to download this attachment.
    [CBU/BK7231N] AVATTO GDS16 WiFi relay module - Sensor Problemback_1.png (5.32 MB)You must be logged in to download this attachment.
    I was able to get the original firmware and get the info below:
    I: UPK: Found BK7231N config!
    I: UPK: Switch/plug config
    I: UPK:  - relay 1: pin P6
    I: UPK:  - button 1: pin P26
    I: UPK: Status LED: pin P9, inverted False
    After that, flashing the ESPhome kickstart firmware was easy.
    The relay and the LED work fine, no problem at all, but I was not able to make the sensor pin work.
    I try to mark the pin as an input_pullup and other pins as well, but nothing works.
    I have two of it and the result is the same for both.
    Can someone help me figure this out?
    This is the code that I use:
    Suggesting flash backup check and pull-up tests
    #2 21910378
    Rate: 12806
    Do you have original 2 MB flash backup so we can double check?
    So basically, extraction tool determined that P26 is input/button, but yet it's not working at all? Have you tried all pull up/down/etc combinations?
    And you are saying that both pieces are not working.... maybe a software error?
    Have you tried to configure it, for now, as a simple switch, without delayed_on_off?
    Curious how it would work with OpenBeken?
  • Tuya pin mapping for button, sensor, relay and LED
    #3 21939289
    gobbirock
    Hi p.kaczmarek2
    I uploaded the original flash so you can take a look too.
    I was using the ltchiptool to get the information from the original firmware, now I try to use the BK7231GUIFlashTool and get new info.
    - Button (channel 1) on P26
    - WiFi LED on P9
    - Door Sensor (channel 1) on P8
    - Relay (channel 1) on P6
    The pin 26 is the Button behind the the device, the door sensor is in the Pin 8.
    I flash it again with the kickstart to test it, but still not working.
    kickstart-bk7231n panel showing pin P26/PWM5 settings and event log on the right
    I am going to try with the OpenBeken to see if it works with it.
    • atto-garagem.bin (2 MB) You must be logged in to download this attachment.
  • #4 21939616
    gobbirock
    I'm so stupid, the magnetic sensor is in the S3+S4 contacts, not in the S1+S2, this are the relay contacts
    Any way, this are the correct pins!
    - WiFi LED on P9
    One more thing hacked successfully! tks
